04-25-2015, 16:36 | #1 (permalink) |
Freak Poster Join Date: Nov 2012
Member: 1841293 Status: Offline Sonork: nour Thanks Meter: 14 | i9500 restart problem and cannot be flashed but all in vain where is the solution thanx in advance |
04-25-2015, 16:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Hello. Please fully charge phone's battery and try to reflash it. Post here full Software log of "Write Firmware" operation. |
04-25-2015, 17:07 | #5 (permalink) |
Member: 1841293 Status: Offline Sonork: nour Thanks Meter: 14 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.1 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: I9500XXUFNF3_I9500OJVFNF3 _TUR_Turkey_Android_4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed |
04-25-2015, 18:00 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Try to reflash the phone with 5.0.1 firmware from the Support Area. If problem will remain the same - most likely this is HW problem (with phone's flash chip). |
