N910g hangs after flash dead. DEAR, 910G HANGS DURING FLASH, GOT STRUCK LOGS HERE.. Performed by 2.4.2 Software version. WARN : 11/21/2016 1:57:49 PM > Please put the phone into Download Mode and connect USB cable. WARN : 11/21/2016 1:57:49 PM > To put SM-N910G into Download Mode, You have to perform the following steps: WARN : 11/21/2016 1:57:49 PM > 1. Reconnect the battery. WARN : 11/21/2016 1:57:49 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 11/21/2016 1:57:49 PM > 3. When phone turns on, press "Volume+" key. INFO : 11/21/2016 1:57:49 PM > Found phone on INFO : 11/21/2016 1:57:49 PM > Firmware write started. INFO : 11/21/2016 1:57:50 PM > Writing ABOOT section... INFO : 11/21/2016 1:57:52 PM > ABOOT section has been written successfully. INFO : 11/21/2016 1:57:52 PM > Writing SBL1 section... INFO : 11/21/2016 1:57:54 PM > SBL1 section has been written successfully. INFO : 11/21/2016 1:57:54 PM > Writing RPM section... INFO : 11/21/2016 1:57:56 PM > RPM section has been written successfully. INFO : 11/21/2016 1:57:56 PM > Writing TZ section... INFO : 11/21/2016 1:57:58 PM > TZ section has been written successfully. INFO : 11/21/2016 1:57:58 PM > Writing DBI section... INFO : 11/21/2016 1:58:00 PM > DBI section has been written successfully. INFO : 11/21/2016 1:58:00 PM > Writing APNHLOS section... INFO : 11/21/2016 1:58:04 PM > APNHLOS section has been written successfully. INFO : 11/21/2016 1:58:04 PM > Writing BOOT section... INFO : 11/21/2016 1:58:07 PM > BOOT section has been written successfully. INFO : 11/21/2016 1:58:07 PM > Writing RECOVERY section... INFO : 11/21/2016 1:58:10 PM > RECOVERY section has been written successfully. INFO : 11/21/2016 1:58:10 PM > Writing SYSTEM section... INFO : 11/21/2016 2:01:43 PM > SYSTEM section has been written successfully. INFO : 11/21/2016 2:01:43 PM > Writing PERSIST section... INFO : 11/21/2016 2:01:46 PM > PERSIST section has been written successfully. INFO : 11/21/2016 2:01:46 PM > Writing MODEM section... INFO : 11/21/2016 2:01:52 PM > MODEM section has been written successfully. INFO : 11/21/2016 2:01:52 PM > Writing CACHE section... GOT STRUCK HERE .... INFO : 11/21/2016 3:38:08 PM > Writing firmware Canceled ANU SUGGESTION PL BR.. |
Hello. What is exact state of the phone? Why did You decide to reflash it? |
Dear, set was in hang condition. During flashing it got struck @ 87%..getting into flashmode.. Br |
Try to perform "Write Firmware" operation again, with enabled "Advanced Mode" option. Un-check "CACHE" partition during the process (leave all partitions checked, except of CACHE). |
DEAR, AFTER UNCHK CACHE & OTHER CHK HERE IS THE LOGS To put SM-N910Gnto Download Mode, You have to perform the following steps: WARN : 11/22/2016 7:01:09 PM > 1. Reconnect the battery. WARN : 11/22/2016 7:01:09 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 11/22/2016 7:01:09 PM > 3. When phone turns on, press "Volume+" key. INFO : 11/22/2016 7:01:09 PM > Found phone on WARN : 11/22/2016 7:01:10 PM > Advanced mode! INFO : 11/22/2016 7:01:57 PM > Firmware write started. INFO : 11/22/2016 7:01:57 PM > Writing ABOOT section... INFO : 11/22/2016 7:01:59 PM > ABOOT section has been written successfully. INFO : 11/22/2016 7:01:59 PM > Writing SBL1 section... INFO : 11/22/2016 7:02:01 PM > SBL1 section has been written successfully. INFO : 11/22/2016 7:02:01 PM > Writing RPM section... INFO : 11/22/2016 7:02:03 PM > RPM section has been written successfully. INFO : 11/22/2016 7:02:03 PM > Writing TZ section... INFO : 11/22/2016 7:02:05 PM > TZ section has been written successfully. INFO : 11/22/2016 7:02:05 PM > Writing DBI section... INFO : 11/22/2016 7:02:08 PM > DBI section has been written successfully. INFO : 11/22/2016 7:02:08 PM > Writing APNHLOS section... INFO : 11/22/2016 7:02:12 PM > APNHLOS section has been written successfully. INFO : 11/22/2016 7:02:12 PM > Writing BOOT section... INFO : 11/22/2016 7:02:15 PM > BOOT section has been written successfully. INFO : 11/22/2016 7:02:15 PM > Writing RECOVERY section... INFO : 11/22/2016 7:02:19 PM > RECOVERY section has been written successfully. INFO : 11/22/2016 7:02:19 PM > Writing SYSTEM section... INFO : 11/22/2016 7:06:58 PM > SYSTEM section has been written successfully. INFO : 11/22/2016 7:06:59 PM > Writing PERSIST section... INFO : 11/22/2016 7:07:01 PM > PERSIST section has been written successfully. INFO : 11/22/2016 7:07:01 PM > Writing MODEM section... INFO : 11/22/2016 7:07:09 PM > MODEM section has been written successfully. INFO : 11/22/2016 7:07:09 PM > Writing HIDDEN section... INFO : 11/22/2016 7:07:14 PM > HIDDEN section has been written successfully. ERROR : 11/22/2016 7:11:50 PM > Writing Firmware Failed INFO : 11/22/2016 7:11:50 PM > Performed by 2.4.2 Software version. STILL GOT HANGED WITH RECOVERY MODE BR.. |
Please repeat "Write Firmware" operation, with enabled "Advanced Mode" option. Un-check both "CACHE" and "HIDDEN" partition during the process |
DEAR, IT GOT STRUCK HERE NOW.. Firmware write started. INFO : 11/22/2016 10:08:17 PM > Writing ABOOT section... INFO : 11/22/2016 10:08:19 PM > ABOOT section has been written successfully. INFO : 11/22/2016 10:08:19 PM > Writing SBL1 section... INFO : 11/22/2016 10:08:21 PM > SBL1 section has been written successfully. INFO : 11/22/2016 10:08:21 PM > Writing RPM section... INFO : 11/22/2016 10:08:23 PM > RPM section has been written successfully. INFO : 11/22/2016 10:08:23 PM > Writing TZ section... INFO : 11/22/2016 10:08:25 PM > TZ section has been written successfully. INFO : 11/22/2016 10:08:25 PM > Writing DBI section... INFO : 11/22/2016 10:08:27 PM > DBI section has been written successfully. INFO : 11/22/2016 10:08:27 PM > Writing APNHLOS section... INFO : 11/22/2016 10:08:31 PM > APNHLOS section has been written successfully. INFO : 11/22/2016 10:08:31 PM > Writing BOOT section... INFO : 11/22/2016 10:08:35 PM > BOOT section has been written successfully. INFO : 11/22/2016 10:08:35 PM > Writing RECOVERY section... INFO : 11/22/2016 10:08:38 PM > RECOVERY section has been written successfully. INFO : 11/22/2016 10:08:38 PM > Writing SYSTEM section... INFO : 11/22/2016 10:13:21 PM > SYSTEM section has been written successfully. INFO : 11/22/2016 10:13:21 PM > Writing PERSIST section... INFO : 11/22/2016 10:13:23 PM > PERSIST section has been written successfully. INFO : 11/22/2016 10:13:23 PM > Writing MODEM section... INFO : 11/22/2016 10:13:31 PM > MODEM section has been written successfully. BR.. |
Try to write "N910GDTS1DPJ2_N910GODD1DPH4_INS_Android_6.0.1 " firmware from the Support Area and post here the result. |
