10-06-2016, 12:01 | #1 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1698387 Status: Offline Thanks Meter: 43 | J320fn write failed Welcome to Octoplus/Octopus Box Samsung software version 2.3.8 ----------------------------------------------------------------------------------- To connect SM-J320FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: J320FNXXU0APH1_J320FNBTU0APH1 _BTU_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J320FN into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. Performed by 2.3.8 Software version. Selected firmware file: J320FNXXU0APE4_J320FNOXX0APD2 _XEF_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J320FN into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. Performed by 2.3.8 Software version. |
10-06-2016, 12:09 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to select SM-J320F model and repeat "Write Firmware" operation. |
10-06-2016, 13:01 | #3 (permalink) |
Member: 1698387 Status: Offline Thanks Meter: 43 | Yes! Its working now! This phone is stuck in safe mode!? What can be the problem? Please help! Welcome to Octoplus/Octopus Box Samsung software version 2.3.8 ----------------------------------------------------------------------------------- To connect SM-J100H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: j100hxxu0aoa8_j100hojv0aoa3_lys_android_ 4.4.4.oct Please put the phone into Download Mode and connect USB cable. To put SM-J100H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing system section... system section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing WDSP section... WDSP section has been written successfully. Writing wfixnv2 section... wfixnv2 section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.3.8 Software version. Selected firmware file: J320FNXXU0APE4_J320FNOXX0APD2 _XEF_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J320F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing SBOOT section... SBOOT section has been written successfully. Writing SBOOT2 section... SBOOT2 section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing l_modem section... l_modem section has been written successfully. Writing l_gdsp section... l_gdsp section has been written successfully. Writing l_ldsp section... l_ldsp section has been written successfully. Writing l_warm section... l_warm section has been written successfully. Writing pm_sys section... pm_sys section has been written successfully. Writing l_fixnv2 section... l_fixnv2 section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.3.8 Software version. -------------------------------------------------------------------------------------- Selected interface: UART Searching for device. Please wait... Device not found! Operation was cancelled! Performed by 2.3.8 Software version. -------------------------------------------------------------------------------------- Selected interface: UART Searching for device. Please wait... Device not found! Operation was cancelled! Performed by 2.3.8 Software version. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Found device on COM112 Reading info... Detected device model: SM-J320FN HW Version: SM2J320FZDNETL PDA version: J320FNXXU0APE4 CSC version: J320FNOXX0APD2 CP version: J320FNXXU0APFG Device SN: R58H509M0RP Device IMEI: 359464-07-393807-3 FRP/Reactivation: UNLOCK Performed by 2.3.8 Software version. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Found device on COM112 Reading info... Detected device model: SM-J320FN HW Version: SM2J320FZDNETL PDA version: J320FNXXU0APE4 CSC version: J320FNOXX0APD2 CP version: J320FNXXU0APFG Device SN: R58H509M0RP Device IMEI: 359464-07-393807-3 FRP/Reactivation: UNLOCK Connecting to server.. Username: Authorization.. Login error: Wrong username! Performed by 2.3.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-J320F Searching for a phone (waiting for ADB device)... Please, press "OK" button on the phone to allow USB debugging.. Reading info... Detected phone model: SM-J320FN Firmware compiled date: Thu May 19 19:33:09 KST 2016 PDA version: J320FNXXU0APE4 CSC version: J320FNOXX0APD2 SW version: J320FNXXU0APFG Phone SN: R58H509M0RP Android version: 5.1.1 (LMY47V) Sales code: ETL Country: Czech Republic HW platform: sc8830 HW Chip: SC9830I HW Modem: SC9830i Codename: j3xnltexx Resetting FRP lock.. Reset FRP cancelled! Operation was canceled Performed by 2.3.8 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-J320F Detected phone model: SM-J320FN Firmware compiled date: Thu May 19 19:33:09 KST 2016 PDA version: J320FNXXU0APE4 CSC version: J320FNOXX0APD2 SW version: J320FNXXU0APFG Phone SN: R58H509M0RP Android version: 5.1.1 (LMY47V) Sales code: ETL Country: Czech Republic HW platform: sc8830 HW Chip: SC9830I HW Modem: SC9830i Codename: j3xnltexx Rebooting phone in Download Mode... Phone successfully rebooted in Download Mode. Performed by 2.3.8 Software version. Selected firmware file: J320FNXXU0APH1_J320FNBTU0APH1 _BTU_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J320F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing SBOOT section... SBOOT section has been written successfully. Writing SBOOT2 section... SBOOT2 section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing l_modem section... l_modem section has been written successfully. Writing l_gdsp section... l_gdsp section has been written successfully. Writing l_ldsp section... l_ldsp section has been written successfully. Writing l_warm section... l_warm section has been written successfully. Writing pm_sys section... pm_sys section has been written successfully. Writing l_fixnv2 section... l_fixnv2 section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.3.8 Software version. |
10-06-2016, 13:05 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to make Factory Reset and Wipe Cache partition from Recovery Mode. |
