08-08-2016, 11:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: United Arab Emirates Age: 43
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | I9505 firmware needed |
08-08-2016, 12:06 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Unfortunately we don't have such firmware at the moment. You can try to reflsah the phone with any Android 5.0.1 firmware from the Support Area. |
08-08-2016, 15:06 | #3 (permalink) |
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | i flash with I9505XXUHOJ2_I9505OJVHOI2_XSI_Android_5.0.1.oct after flash during booting set warranty bit : kernal in yellow and No wifi and No Sim card. kindly guide me to resolve this issue. Here is the logs. Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\08-08-2016_17-19-30.log" created (8/8/2016 5:19:33 PM). INFO : 8/8/2016 5:19:39 PM > Set up system language English (file: English.ini) INFO : 8/8/2016 5:19:39 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.3.0 INFO : 8/8/2016 5:19:43 PM > ----------------------------------------------------------------------------------- INFO : 8/8/2016 5:19:43 PM > To connect GT-I9505 phone you have to perform the following steps: INFO : 8/8/2016 5:19:43 PM > 1. Disconnect USB cable from phone. INFO : 8/8/2016 5:19:43 PM > 2. Go to Menu->Settings->More->About Device. INFO : 8/8/2016 5:19:43 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 8/8/2016 5:19:43 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 8/8/2016 5:19:43 PM > 5. Turn on "USB Debugging" option. INFO : 8/8/2016 5:19:43 PM > 6. Go to dial window. INFO : 8/8/2016 5:19:43 PM > 7. Enter "*#0808#" number. INFO : 8/8/2016 5:19:43 PM > 8. Select "DM+Modem+ADB". INFO : 8/8/2016 5:19:43 PM > 9. Press Home button. INFO : 8/8/2016 5:19:43 PM > 10. Restart phone. INFO : 8/8/2016 5:19:43 PM > 11. Press "Read Info" in software. INFO : 8/8/2016 5:26:14 PM > Selected firmware file: I9505XXUHOJ2_I9505OJVHOI2_XSI_Android_5.0.1.oct WARN : 8/8/2016 5:26:20 PM > Please put the phone into Download Mode and connect USB cable. WARN : 8/8/2016 5:26:20 PM > To put GT-I9505 into Download Mode, You have to perform the following steps: WARN : 8/8/2016 5:26:20 PM > 1. Reconnect the battery. WARN : 8/8/2016 5:26:20 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 8/8/2016 5:26:20 PM > 3. When phone turns on, press "Volume+" key. INFO : 8/8/2016 5:26:20 PM > Found phone on INFO : 8/8/2016 5:26:20 PM > Firmware write started. INFO : 8/8/2016 5:26:20 PM > Writing ABOOT section... INFO : 8/8/2016 5:27:07 PM > ABOOT section has been written successfully. INFO : 8/8/2016 5:27:07 PM > Writing SBL1 section... INFO : 8/8/2016 5:27:55 PM > SBL1 section has been written successfully. INFO : 8/8/2016 5:27:55 PM > Writing SBL2 section... INFO : 8/8/2016 5:28:42 PM > SBL2 section has been written successfully. INFO : 8/8/2016 5:28:42 PM > Writing SBL3 section... INFO : 8/8/2016 5:29:29 PM > SBL3 section has been written successfully. INFO : 8/8/2016 5:29:29 PM > Writing RPM section... INFO : 8/8/2016 5:30:16 PM > RPM section has been written successfully. INFO : 8/8/2016 5:30:16 PM > Writing TZ section... INFO : 8/8/2016 5:31:03 PM > TZ section has been written successfully. INFO : 8/8/2016 5:31:03 PM > Writing BOOT section... INFO : 8/8/2016 5:31:07 PM > BOOT section has been written successfully. INFO : 8/8/2016 5:31:07 PM > Writing RECOVERY section... INFO : 8/8/2016 5:31:11 PM > RECOVERY section has been written successfully. INFO : 8/8/2016 5:31:11 PM > Writing SYSTEM section... INFO : 8/8/2016 5:39:18 PM > SYSTEM section has been written successfully. INFO : 8/8/2016 5:39:18 PM > Writing MDM section... INFO : 8/8/2016 5:40:14 PM > MDM section has been written successfully. INFO : 8/8/2016 5:40:14 PM > Writing APNHLOS section... INFO : 8/8/2016 5:41:03 PM > APNHLOS section has been written successfully. INFO : 8/8/2016 5:41:03 PM > Writing CACHE section... INFO : 8/8/2016 5:41:45 PM > CACHE section has been written successfully. INFO : 8/8/2016 5:41:45 PM > Writing HIDDEN section... INFO : 8/8/2016 5:42:39 PM > HIDDEN section has been written successfully. INFO : 8/8/2016 5:42:39 PM > Firmware writing successfully completed. INFO : 8/8/2016 5:42:39 PM > Performed by 2.3.0 software version |
