N910v version 5.0.1 can't unlock please how to enable Diagnostic port? I have tried all I could do to unlock this N910v on android 5.0.1 but it didnt just work, I think the problem is that the diagonistic port is not working, I used the enable diag button but it didnt enable the port, please how will I unlock this phone? Logs; Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- To connect SC-06D phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N910V phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM17 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM13 Phone connection failed Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Detected phone model: SM-N910V Firmware compiled date: Fri Jul 31 15:49:35 KST 2015 PDA version: N910VVRU2BOG5 CSC version: N910VVZW2BOG5 SW version: N910VVRU2BOG5 Phone SN: 00000000000 Android version: 5.0.1 (LRX22C) Updating DIAG confing... DIAG confing is succesfully enabled. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.2.1 software version |
Hello. Please select "DM+Modem+ADB" option in *#0808# (##3424#) menu, then try to perform "Unlock" operation again. Try to perform the operation on different COM ports, with enabled "Manual select" option. |
Thanks for your fast reply. I have typed *#0808# and ##3424# but nothing like "DM+Modem+ADB" showed up (Nothing at all showed up talk more of "DM+Modem+ADB"). I have flashed the phone with odin, hardreset it but nothing happened when I use the codes above, please any other help? Thanks! |
Please repeat "Enable DIAG" operation, then try to read phone's info from "Main" tab of the Software on different COM ports, with enabled "Manual select" option. |
It didnt work and when I go to the device manager, am not seeing the diagnostic prot only the modem port, below is log; Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- To connect SC-06D phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Detected phone model: SM-N910V Firmware compiled date: Fri Jul 31 15:49:35 KST 2015 PDA version: N910VVRU2BOG5 CSC version: N910VVZW2BOG5 SW version: N910VVRU2BOG5 Phone SN: 00000000000 Android version: 5.0.1 (LRX22C) Updating DIAG confing... DIAG confing is succesfully enabled. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Phone was not found on the selected port! Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Detected phone model: SM-N910V Firmware compiled date: Fri Jul 31 15:49:35 KST 2015 PDA version: N910VVRU2BOG5 CSC version: N910VVZW2BOG5 SW version: N910VVRU2BOG5 Phone SN: 00000000000 Android version: 5.0.1 (LRX22C) Updating DIAG confing... DIAG confing is succesfully enabled. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Phone was not found on the selected port! Performed by 2.2.1 software version |
Please check whether phone accepts ##366633# code. |
Yes sir it accept that and shows "Enable DM Mode"and "Disable DM Mode" and the radio button of "Disable DM Mode" is the one marked, should I change it? |
Now it can see the diagnostic port and can unlock, but the phone is not yet unlocked, still showing "sim card is not from Verizon" and I have changed it from LTE to LTE/GSM/UMTS, please what else will I do it? UNLOCKING LOGS Welcome to Octoplus/Octopus Box Samsung software version 2.2.1 ----------------------------------------------------------------------------------- To connect SC-06D phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910V Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM13 Phone connection failed Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SM-N910V Mode: Normal Phone model: SM-N910V Firmware compiled date: May 29 2015 Firmware compiled time: 17:00:00 Firmware released date: Jul 30 2015 Firmware released time: 14:26:02 Phone IMEI: 990004-82-052224-5 SW version: MPSS.DI.3.0.c5-00352-M9625TAARANSZM- 1.12401.1.19811.1.20883.1.21300.1 Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SM-N910V Reading info... Mode: Normal Firmware compiled date: May 29 2015 Firmware compiled time: 17:00:00 Firmware released date: Jul 30 2015 Firmware released time: 14:26:02 SW Version: MPSS.DI.3.0.c5-00352-M9625TAARANSZM- 1.12401.1.19811.1.20883.1.21300.1 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.1 software version |
Please check whether phone obtains Network (also try to find and select manually), despite the "sim card is not from Verizon" message. |
It doest not obtain network, should I download version 5.1.1 and update it with it? |
We recommend not to upgrade firmware version. Try to set Network Mode to Global, then try to find and select Network manually again. |
Note 4 N910V 4.4.4 Network not come After Unlock and NV Repair failed... Platform: Samsung Android Selected port: COM37 Selected model: SM-N910V Reading info... Mode: Normal Firmware compiled date: Aug 27 2014 Firmware compiled time: 08:00:00 Firmware released date: Sep 15 2014 Firmware released time: 09:52:07 SW Version: MPSS.DI.3.0.c5-00228-M9625TAARANAZM-1 ADB server killed. Detected phone model: SM-N910V Firmware compiled date: Tue Sep 16 18:53:12 KST 2014 PDA version: N910VVRU1ANI1 CSC version: N910VVZW1ANI1 SW version: N910VVRU1ANI1 Phone IMEI: 990004957394566 Phone SN: 00000000000 Android version: 4.4.4 (KTU84P) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-N910V-01-03-2016_16-58-58 file Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.1 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM37 Selected model: SM-N910V Mode: Normal Phone model: SM-N910V Firmware compiled date: Aug 27 2014 Firmware compiled time: 08:00:00 Firmware released date: Sep 15 2014 Firmware released time: 09:52:07 Phone IMEI: 990004-95-739456-6 SW version: MPSS.DI.3.0.c5-00228-M9625TAARANAZM-1 Creating NVM backup NVM reading process failed Repairing NVM for SM-N910V phone... Writing NVM failed NVM repair completed successfully Phone will restart now Performed by 2.2.1 software version |
Please set Network Mode to Global, then try to find and select Network manually. |
http://s5.postimg.org/s7f27ftdf/001.jpg http://s5.postimg.org/na1hmbreb/002.jpg http://s5.postimg.org/k4gvw48s3/003.jpg http://s5.postimg.org/71l9cuik3/004.jpg http://s5.postimg.org/9k6ydj4ab/005.jpg http://s5.postimg.org/sqoquga5v/006.jpg http://s5.postimg.org/pxvjaf9tf/007.jpg |
Try to reflash the phone, then try to find and select Network manually (not via Automatic registration). |
