03-06-2023, 21:01 | #1 (permalink) |
Freak Poster Join Date: May 2013
Member: 1929380 Status: Offline Sonork: john-ammu Thanks Meter: 6 | Need SM-G955N U4 Android 9 Root [Answered] bootloader says official relessed binaries are allowed to be flashed. Phone firmware version G955NKSU4DSK2 |
03-08-2023, 20:45 | #3 (permalink) |
Member: 1929380 Status: Offline Sonork: john-ammu Thanks Meter: 6 | i have found the Solution i am not taking Creadit. i am not creticize/Degrade anybody I am NOT responsible for any damage done if you use my guide. It worked for me 100% and should normally work for everybody! Feel free to share to anyone else or to embed if you want. ------------------------------------------------- 1. Download latest Stock base via SamFirm 2. Install latest Stock base via Odin Odin v3.13.1 direct download 3. Boot into system 4. Skip the setup 5. Activate Developer settings 6. search and turn of automatic system update 7. Go to time settings and deactivate automatic time 8. Turn back the day for more than 7 days. ( I have turned to the 20th Dec 2018) 9. Search for Software update -> Don't install update 10. Look if latest time searched for updates is the date which you have set. (for me 20th Dec 2018) 11. Reboot your device 12. go into the time settings and reactivate the automatic time 13. Search again for software update - > Still don't install 14. Go to Developer settings 15. deactivate OEM Unlock and reactivate 16. Go to download mode and you will don't see RMM state anymore 18. install TWRP by odin 19. boot into TWRP 20. format data 21. reboot recovery 22. flash verity.zip // found on https://build.nethunter.com/android-...y-opt-encrypt/ 23. Et voilą! You got completely functional TWRP on your device with Pie Bootloader 24. Flash your preferred Rom! ------------------------------------------------- Thanks to: zxz0O0 for SamFirm Have Fun List of Files 1. Twrp-3.3.0-0-G955_dream2lte.img.tar/ or download the Latest Twrp (with Odin). wipe then Format and then Reboot recovery. 2. no-verity-opt-encrypt-6.1.zip (with Twrp) 3. Magisk-v19.3.zip (with Twrp). this will boot normal finish Setup wizard install 4. MagiskManager-v7.3.2.apk 5. Root_Checker.apk Last edited by john-ammu; 03-08-2023 at 20:52. |
