05-04-2015, 21:17 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2136107 Status: Offline Thanks Meter: 0 | octoplus 1.9.4 BAD SOFTWARE 2 samsung no imei fix I begin by saying that I tried all the Android versions for these two phones up to three days ago I had the 1.8.xx (can not remember exactly) and everything worked perfectly I did in the past weeks is the first known 3 sm n9005 a s5 sm g900f and I have never experienced something like that (again with version 1.8.xx) since I tried everything (I even formatted the PC and changed many as 3 USB cables) what can I do now?!?! dates at least the ability to download old versions of the program I expect a sensible answer while I copy all of the LOG and 2 terminals Welcome to Octoplus/Octopus Box Samsung software version 1.9.4 ----------------------------------------------------------------------------------- To connect SM-G900F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Reading info, please wait... Detected phone model: SM-N9005 Firmware compiled date: Mon Apr 14 17:38:48 KST 2014 PDA version: N9005XXUEND3 CSC version: N9005ITVEND1 SW version: N9005XXUGNG1 Phone IMEI: Unknown Phone SN: RF1D93DDX6H Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Detected phone model: SM-N9005 Firmware compiled date: Mon Apr 14 17:38:48 KST 2014 PDA version: N9005XXUEND3 CSC version: N9005ITVEND1 SW version: N9005XXUGNG1 Phone IMEI: Unknown Phone SN: RF1D93DDX6H Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Apr 04 2014 Firmware compiled time: 16:00:00 Firmware released date: Jul 28 2014 Firmware released time: 19:44:59 SW Version: M8974A-AAAANAZM-1.0.180102A Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N9005-04-05-2015_22-01-43-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Apr 04 2014 Firmware compiled time: 16:00:00 Firmware released date: Jul 28 2014 Firmware released time: 19:44:59 SW Version: M8974A-AAAANAZM-1.0.180102A Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Selected file: C:\Users\saurus\Downloads\Cert-SM-N9005_ 357518050231117.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- To connect SM-G900F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G900F Reading info, please wait... Detected phone model: SM-G900F Firmware compiled date: Fri Jul 25 19:07:06 KST 2014 PDA version: G900FXXU1ANG9 CSC version: G900FITV1ANG3 SW version: G900FXXU1ANG8 Phone IMEI: 353222066077275 Phone SN: RF8F40RFRXA Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G900F Detected phone model: SM-G900F Firmware compiled date: Fri Jul 25 19:07:06 KST 2014 PDA version: G900FXXU1ANG9 CSC version: G900FITV1ANG3 SW version: G900FXXU1ANG8 Phone IMEI: 353222066077275 Phone SN: RF8F40RFRXA Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 23 2014 Firmware released time: 19:34:35 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G900F-353222066077275-04-05-2015_22-06- 30-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Jun 10 2014 Firmware compiled time: 07:00:00 Firmware released date: Jul 23 2014 Firmware released time: 19:34:35 SW Version: MPSS.DI.2.0.1.c2-00064-M8974AAAAANRZM-1 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G900F Selected file: C:\Users\saurus\Downloads\Cert-SM-G900F_ 352558067456401_00000000000.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed |
05-05-2015, 08:17 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Hello. In order to connect the phone via UART, You need to block highlighted pin with a tape/paper and use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. |
The Following 4 Users Say Thank You to Octopus box For This Useful Post: |
05-07-2015, 12:45 | #3 (permalink) |
Member: 2136107 Status: Offline Thanks Meter: 0 | ok the s5 has been successful using only the USB cable (why?) Now the problem is the note 3 unfortunately I always mistake the sw version unknown with sw unknown I can not fix the imei I know it seems that the modem has been corrupted after putting lollipop (android5) Now I found a firmware that gives me nancy (fw 4.4.2 N9005XXUGNG1_ITA Italian) fact the log is so Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Detected phone model: SM-N9005 Firmware compiled date: Mon Apr 14 17:38:48 KST 2014 PDA version: N9005XXUEND3 CSC version: N9005ITVEND1 SW version: N9005XXUGNG1 Phone IMEI: Unknown Phone SN: RF1D93DDX6H Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Apr 04 2014 Firmware compiled time: 16:00:00 Firmware released date: Jul 28 2014 Firmware released time: 19:44:59 SW Version: M8974A-AAAANAZM-1.0.180102A Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N9005-04-05-2015_22-01-43-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Apr 04 2014 Firmware compiled time: 16:00:00 Firmware released date: Jul 28 2014 Firmware released time: 19:44:59 SW Version: M8974A-AAAANAZM-1.0.180102A Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Selected file: C:\Users\saurus\Downloads\Cert-SM-N9005_ 357518050231117.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed Unfortunately, the problem is the same does not seem to connect I can only try that part modem What do you advise me to do ?! try uploading your fw part modem that works? help me please l hw works perfectly I have already tried rest of the opinion that quesa version software does not work with the 1.8.xx since it was all right because I fixed a imei to a note3 only with the help of usb cable samsung (no uart) |
05-07-2015, 14:00 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Try to reinstall FTDI drivers (http://octoplusbox.com/files/drivers...rs_2.08.24.zip). Try to use another Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. Try to use another box as UART interface. |
05-07-2015, 16:52 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Please check the following manual on how to install/uninstall FTDI drivers: http://www.ftdichip.com/Support/Docu...r_Windows7.pdf |
05-11-2015, 16:50 | #7 (permalink) |
Member: 2136107 Status: Offline Thanks Meter: 0 | congratulations for seriousness you deleted the posts of other users who had problems with 1.9.4 I also tried the 1.9.5 and the problems are still the same by chance I found on my hdd version 1.6.4 of octoplus the process is the same but as I insert the cable uart lights on taking octopus flash ( at least it has signs of life in comparison to the recent version ) unfortunately I do not fix the imei most do not know what to do except try the 1.8 that you do not want me to try I am very disappointed regards |
05-11-2015, 17:40 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Please attentively read previous post, in which we suggested You what to do. Quote:
05-11-2015, 20:53 | #9 (permalink) |
Member: 2136107 Status: Offline Thanks Meter: 0 | i have try all the things you have show me i have only octopus box and medusa box whit the 1.8 sw the imei fix is very easy and fast it is impossible that with the octopus does not work as it has always worked well it is software problem I'm afraid there is no alternative I tried all your fw all Italian and European fw 3 cables with uart reistenza 525 530k sw versions 1.9.2 1.9.3 1.9.4 1.9.5 octoplus and 1.6.4 I tried to follow all your istruziioni including putting the tape on the battery contact and reinstall the drivers that made me download I also formatted the computer to delete all the logs but also nothing to do datei can download the 1.8 and I show that within 10 minutes the problem is resolved because I made a note imei Fix a 3 smn 9005 three weeks ago with the 1.8 |
05-12-2015, 07:40 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Please do the next: 1. Install latest Software version. 2. Block appropriate battery pin. 3. Repeat "Write Cert" operation. 4. Close the Software. 5. Upload latest *.log and *.logx files from "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder and post here download link. We will check where can be the problem. Last edited by Octopus box; 05-12-2015 at 08:37. |
05-12-2015, 09:09 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Please check your PM, we have sent You test Software version. Try to perform "Write Cert" operation with test Software and post results. |
05-12-2015, 09:42 | #13 (permalink) |
Member: 2136107 Status: Offline Thanks Meter: 0 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.5 ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Detected phone model: SM-N9005 Firmware compiled date: Mon Jul 28 21:56:29 KST 2014 PDA version: N9005XXUGNG1 CSC version: N9005ITVGNG1 SW version: N9005XXUGNG1 Phone IMEI: Unknown Phone SN: RF1D93DDX6H Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Apr 04 2014 Firmware compiled time: 16:00:00 Firmware released date: Jul 28 2014 Firmware released time: 19:44:59 SW Version: M8974A-AAAANAZM-1.0.180102A Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N9005-12-05-2015_10-37-56-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Apr 04 2014 Firmware compiled time: 16:00:00 Firmware released date: Jul 28 2014 Firmware released time: 19:44:59 SW Version: M8974A-AAAANAZM-1.0.180102A Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N9005 Selected file: C:\Users\saurus\Downloads\Cert-SM-N9005_ 357518050231117.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed it's the same |
05-12-2015, 10:07 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,435 | Please upload log and logx files of the operation. Post here download link, we will check where can be the problem. |
