09-10-2017, 08:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | imei unkonow ----------------------------------------------------------------------------------- To connect SM-J710FD phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-J710FD Detected phone model: SM-J710F Firmware compiled date: Tue Jul 25 17:37:47 KST 2017 PDA version: J710FXXS3AQG1 CSC version: J710FOJV2AQB2 SW version: unknown Phone SN: 00000000000 Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7870 HW Modem: unknown Security patch level: 2017-07-01 SIM 1 status: not ready SIM 2 status: not ready Codename: j7xeltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-J710FD-Unknown10-09-2017_00-29-00-.asec file Connecting to modem port... Modem port was not found! Initializing exploit... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Executing exploit... Write IMEI failed Performed by 2.5.8 Software version. |
09-10-2017, 13:24 | #2 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hi, the problem in addition to the unknown IMEI you also have the unknown modem part. Having the unknown modem does not allow you to write the IMEI code. So you have to make back the modem part correct and not unknown You can try to write another firmware until the modem part returns correct and then try to rewrite the IMEI code Or if you are writing different firmware you don't find a solution and the modem part remains unknown, you can try to write the security of your phone if you have backed up your phone's security with the program, or you can backup your security, try Write the security and see if the modem part returns correct and not unknown and see if the IMEI code returns to default and then try to write back the IMEI code |
09-11-2017, 18:19 | #3 (permalink) |
Freak Poster Join Date: Mar 2016
Member: 2541673 Status: Offline Thanks Meter: 39 | correct, look the log, you see PDA, CSC, AND SW ... only will work when you see SW: and see build number.. if say UNKNOWN like above log, that means the modem is not compatible and shows as busy or closed... when read phone you see SW not unknow but say DPK4 then you are able to unlock |
09-12-2017, 07:55 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Hello. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. | |
