05-11-2015, 16:33 | #34 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Have setted right this G386T1?... (also i think isn't supprted yet the 1 version), anyway loock here: To connect SM-G386T1 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Br allumts |
The Following User Says Thank You to allumts For This Useful Post: |
05-12-2015, 02:56 | #35 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2238544 Status: Offline Thanks Meter: 0 | i have the octoplus box, samsung tool 1.9.5 the device im repairing is a n910t , i have used octoplus to write the firmware and cache recovery from octoplus. i rooted the device using there method. I then read the device to make sure it was connnected. then i clicked the repair/wipe security button . then i tape the battery it puts the star ( factory mode) in the notifications, the box begins to write then after a short period the device reboots and the program says write cert failed. please help |
05-12-2015, 19:27 | #39 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Quote:
Code: INFO : 12/05/2015 10:55:15 > Platform: Samsung Android INFO : 12/05/2015 10:55:15 > Selected port: COM148 INFO : 12/05/2015 10:55:15 > Selected model: SM-G386T1 INFO : 12/05/2015 10:55:15 > Reading info... INFO : 12/05/2015 10:55:15 > Mode: Normal INFO : 12/05/2015 10:55:15 > Firmware compiled date: Jul 24 2014 INFO : 12/05/2015 10:55:15 > Firmware compiled time: 05:00:00 INFO : 12/05/2015 10:55:15 > Firmware released date: Nov 18 2014 INFO : 12/05/2015 10:55:15 > Firmware released time: 20:09:57 INFO : 12/05/2015 10:55:15 > SW Version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 WARN : 12/05/2015 10:55:16 > Please, press "OK" button on the phone to allow USB debugging.. INFO : 12/05/2015 10:55:18 > Detected phone model: SM-G386T1 INFO : 12/05/2015 10:55:18 > Firmware compiled date: Tue Nov 18 21:07:16 KST 2014 INFO : 12/05/2015 10:55:19 > PDA version: G386T1UVU1ANK3 INFO : 12/05/2015 10:55:19 > CSC version: G386T1TMB1ANK3 INFO : 12/05/2015 10:55:20 > SW version: G386T1UVU1ANK3 INFO : 12/05/2015 10:55:21 > Phone IMEI: 35489706XXXXXXX INFO : 12/05/2015 10:55:21 > Phone SN: R28G334JJYZ INFO : 12/05/2015 10:55:21 > Android version: 4.4.2 (KOT49H) INFO : 12/05/2015 10:55:22 > Checking Root: ERROR : 12/05/2015 10:55:23 > Phone is not Rooted. INFO : 12/05/2015 10:55:23 > Unlocking phone... WARN : 12/05/2015 10:55:24 > Phone will restart now. Please don't disconnect cable! INFO : 12/05/2015 10:55:24 > Phone is successfully unlocked WARN : 12/05/2015 10:55:24 > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\12-05-2015_10-52-16.log" closed (12/05/2015 11:28:16). | |
05-13-2015, 20:40 | #41 (permalink) |
Registered User Join Date: Apr 2006 Location: PERU
Member: 257781 Status: Offline Thanks Meter: 22 | Help Repair Imei Sm-g360m regards Plataforma: Samsung Android Puerto seleccionado: COM13 Modelo seleccionado: SM-G360M Modo: Normal Modelo del teléfono: SM-G360M Fecha de creación del firmware: Dec 03 2014 Tiempo de compilación del firmware: 23:00:00 Fecha de salida del firmware: Dec 30 2014 Tiempo de salida del firmware: 21:24:46 IMEI del teléfono: 357208-06-021079-4 Versión del SW: MPSS.DPM.2.0.c5-00018-M8936FAAAANUZM-1.9964.1.10018.1.10201.1 |
05-14-2015, 16:42 | #44 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ ergoflo123456 Quote:
05-14-2015, 16:45 | #45 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ tdark Quote:
Please create new thread with the problem, read out phone's info via ADB (press "Read info" button at "Android / EFS manager" tab in the Software) and post there full Software log with this info. We will check and try to advise, what to do the next. | |
