09-19-2017, 16:06 | #62 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Platform: Samsung Android Selected port: COM4 Selected model: SM-G530H Selected file: C:\Users\ORHAN5\Desktop\G530H (2).cert Select Certificate2... Selected file: C:\Users\ORHAN5\Desktop\G530H (2).cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM4 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.5.7 Software version. |
The Following User Says Thank You to orhan5 For This Useful Post: |
09-19-2017, 17:40 | #67 (permalink) | |
Insane Poster Join Date: Jan 2014 Location: turkey
Member: 2116073 Status: Offline Thanks Meter: 8 | workssss Quote:
i tried this vers. | |
09-19-2017, 20:41 | #70 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1839387 Status: Offline Thanks Meter: 0 | hi, I have a problem .. I did the procedure to write the imei certificate on a g930f, everything ok, successful writing and network repair ok (i also installed the octonetwork app) .. today I have problems. The network is ok, the signal is there, but when I try to call, or when they call me, the line remains silent both in outgoing call and in incoming call. if I remove the sim from the cellphone turned on and I insert it back in, it all goes back to work .. then after a while the fault recurs .. Can it be a written certificate problem ?? the cell phone works perfectly. Now I'm trying to write imei (without writing the certificate) and repair network so i see if the problem comes back again . |
09-20-2017, 09:56 | #74 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Platform: Samsung Android Selected port: COM4 Selected model: SM-J110H Detected phone model: SM-J110H Firmware compiled date: Sat Jul 25 15:50:45 KST 2015 PDA version: J110HXXU0AOGA CSC version: unknown SW version: J110HXXU0APB2 Phone IMEI: 3xxxxxxxxxxxxxxx Phone SN: RV1J31E7ZLW Android version: 4.4.4 (KTU84P) Sales code: unknown Country: unknown HW platform: sc8830 HW Chip: SC7727S HW Modem: SC7727S SIM 1 status: absent Codename: j1pop3gjv Checking Root: Phone is Rooted. Old IMEI B: 3xxxxxxxxxxxxxxx New IMEI B: 3xxxxxxxxxxxxxxx Repairing IMEI. Please wait... Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.5.7 Software version. |
09-20-2017, 10:52 | #75 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Write any other Firmware with CSC of you country, try since you haven't more this issue. Solved very many times only by Flashing other Firmware, it's Not Cert "Patch" issue, "Imei Repair" itc... Post result. | |
