Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 10-26-2014, 04:40   #61 (permalink)
ngocdiemmobile's Avatar
Member: 1781157
Sonork: 100.1624851
Thanks Meter: 165
how to repair imei g850 supporter if support for me contac
Old 10-26-2014, 05:06   #62 (permalink)
Member: 1582587
Sonork: 100.1654576
Thanks Meter: 20
SM-G900a 4.4.2 really unlocked succeed by OCT 1.7.3 via write cert. Cert-SM-G900F_352558067456393-00000000000.cert (download from OCT support). after Repair/wipe security Done phone Imei will /00 then write cert above will work fine. thank to Octopus team.
Old 10-26-2014, 06:38   #63 (permalink)
Member: 1713362
Thanks Meter: 2
i need n750 certificate file
if someone have please share it.
Old 10-26-2014, 11:05   #64 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 25,131
@ gsgaurav2011
Please check your PM.
Old 10-26-2014, 15:11   #65 (permalink)
Member: 2214386
Thanks Meter: 2
Is note 4 T-Mobile Supported Yet N910T
Old 10-26-2014, 21:21   #66 (permalink)
Member: 2248996
Sm-g900t
Any one has SM-G900T Certificate File Please ?
Old 10-26-2014, 22:41   #67 (permalink)
Member: 2273035
Thanks Meter: 4
Originally Posted by sameenshah123 View Post
i aslo have exact same problem. and its not even doing wife efs.
Look at your log. The EFS has not been wiped its still showing your old IMEI. You cannot write the Cert until it says IMEI is 0 or unknown in log. You have to wipe the EFS first.
Old 10-27-2014, 06:58   #68 (permalink)
zorgy_1979's Avatar
Member: 1331464
Thanks Meter: 187
Same problem with g900f. Wipe efs but after wipe imei is same. And cant write cert. Tried flash software from support. All is same.
Old 10-27-2014, 07:54   #69 (permalink)
Member: 1146942
Sonork: 100.1587278
@ zorgy_1979
Make Factory data reset and wipe cache partition, then root the phone, make Wipe Security, re-start the phone and then Write Cert. Also, look here: http://forum.gsmhosting.com/vbb/f684...olved-1872615/.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 10-27-2014, 10:04   #70 (permalink)
zorgy_1979's Avatar
Member: 1331464
Thanks Meter: 187
Still same
Платформа: Samsung Android
Выбранный порт: COM233
Выбранная модель: SM-G900F
Определена модель телефона: SM-G900F
Дата создания прошивки: Thu May 8 12:44:41 KST 2014
PDA version: G900FXXU1ANE2
CSC version: G900FVIR1AND2
Версия программного обеспечения: G900FXXU1ANE2
IMEI телефона: 35**********
Phone SN: R58F706QCNA
Android version: 4.4.2 (KOT49H)
Reading info...
Mode: Normal
Firmware compiled date: Feb 26 2014
Firmware compiled time: 01:00:00
Firmware released date: May 8 2014
Firmware released time: 10:38:24
SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1
Reading QCN...
Send SPC...
Reading mobile property...
Mobile property read successfully
Reading feature mask...
Feature mask read successfully
Reading roaming list 0
Reading roaming list 0 read successfully
Reading NV items...
NV items read successfully
Reading NV SIM1 items...
NV SIM1 items read successfully
Reading NV SIM2 items...
NV SIM2 items read successfully
Reading NV items...
Reading EFS...
EFS read successfully
Reading provisioning items...
Provisioning items read successfully
Reading QCN done!
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\QCN-SM-G900F-35**********-27-10-2014_14-17-
03-.qcn file
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
\BACKUP\Security-SM-G900F-35********-27-10-2014_14-22-
39-.asec file
Wiping EFS...
EFS wipe successfully
Сейчас телефон будет перезагружен
Searching for a phone. Please wait...
Reading info...
Mode: Normal
Send SPC...
SPC send successfully
Writing QCN...
Writing NV items...
NV items write successfully
Writing NV SIM1 items...
NV SIM1 items write successfully
Writing NV SIM2 items...
NV SIM2 items write successfully
Wrting EFS...
EFS write successfully
Writing provisioning items...
Provisioning items write successfully.
Writing QCN done
Wipe security successfully complete.
Selected file: D:\firmwares\samsung\g900f\cert\Cert-SM-G900F_
352558067456393_00000000000.cert
Checking Root:
Phone is Rooted.
Checking Certificate file...
Certificate file successfully checked
Writing Certificate...
Phone connected successfully
Запись нового IMEI в телефон...
Writing Certificate failed
As i understand problem because efs is not wiped. Think that my problem wrote here. http://forum.gsmhosting.com/vbb/f684...l#post10638884
At second time when wipe cert phone is not reboot automatically.
Господа пробовал по всякому. Попробовал от имени админа и в режиме совместимости с хрюшей. Логи все успешные но имей старый на месте. пробовал по разному. Как ни странно сеть до сих пор еще на месте. По 0011 с сертом все впорядке. 2 раза подряд прогнать wipe пробовал. Галочку напротив порта ставить тоже пробовал.
Old 10-27-2014, 10:06   #71 (permalink)
IkaMazini's Avatar
Member: 162473
Thanks Meter: 581
@zorgy_1979
http://forum.gsmhosting.com/vbb/f684...l#post10638242
Old 10-27-2014, 10:06   #72 (permalink)
IkaMazini's Avatar
Member: 162473
Thanks Meter: 581
Originally Posted by Octopus box View Post
Fully charge phone's battery, make Factory data reset and wipe cache partition and try to repeat Wipe Security again.
Check it out and please post here the result
The Following User Says Thank You to IkaMazini For This Useful Post:
Old 10-27-2014, 10:08   #73 (permalink)
zorgy_1979's Avatar
Member: 1331464
Thanks Meter: 187
Bro i tried it. Efs is not wiped.
The Following User Says Thank You to zorgy_1979 For This Useful Post:
Old 10-27-2014, 10:14   #74 (permalink)
ask-unlock's Avatar
Member: 1254195
Sonork: 5454
Thanks Meter: 111
Originally Posted by trte-mrte View Post
As i can see in your LOG u have original IMEI on phone.
Repeat "Repair/Wipe" procedure until u have IMEI: Unknown.
(If u have original IMEI in phone CERT cannot be written.)
Everyone who has same problem repeat first step until u have IMEI UNKNOWN, problem will be 100% solved!
You are right i do now it's good with cert write,but no signal in the phone?
Old 10-27-2014, 10:21   #75 (permalink)
mrdnice88347's Avatar
Member: 2157134
Thanks Meter: 8
I have signal,just can't find IMEI in the write cert....
Sent from my iPad using Tapatalk
Page generated in 0.42716 seconds with 7 queries
