12-31-2014, 10:26 | #1 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | what is best step for unlock i9505 ? I see many peopel have probleme with unlocking this cell phone, So what is best solutioin for unlocking the i9505 with out loosing the network and flashing phone ? Best Regards, JAVA Good. |
12-31-2014, 10:43 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | To make Unlock, perfrom all the steps :rom Software manual ("Help" button in the Software): 1. Install the latest Software version (Software). 2. Install necessary driver. 3. Root your phone manually. 4. Write firmware "GT-i9505_for_Unlock_and_IMEI_repair" from the Support Area (at first try without writing this frimware, maybe modem firmware in your phone allows to make Unlock). 5. Connect powered-on phone to PC via Micro USB cable. 6. Click "Unlock" button. 7. Follow software instructions (prompts). Also, look here: http://forum.gsmhosting.com/vbb/f684.../#post10675173, http://forum.gsmhosting.com/vbb/10594282-post18.html, http://forum.gsmhosting.com/vbb/f684...l#post10534714, http://forum.gsmhosting.com/vbb/f684.../#post10534692, http://forum.gsmhosting.com/vbb/f684.../#post10666153. |
12-31-2014, 11:16 | #4 (permalink) | ||
Member: 66136 Status: Offline Thanks Meter: 200 | tks for all for help and reply, but I need exactely step ? like, Quote:
I have probleme in this last step : Quote:
Best Regards, JAVA Good. | ||
12-31-2014, 11:33 | #6 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | ok, so exactely step, next time when have one I come back on this thread, tks for all, and pls how to know if the phone is hold or new security pls ? Best Regards, JAVA Good. |
12-31-2014, 11:49 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
12-31-2014, 12:07 | #8 (permalink) |
Major Poster Join Date: Nov 2014 Location: gojra city Age: 38
Member: 2284783 Status: Offline Sonork: 100.1661528 Thanks Meter: 4 | the best way for unlok i9505 1. Phone must be powered on. 2. Type *#0808# and choose, CP install drivers if needed. 3. Type *#9090# and choose DM\DUM over HS-USB. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Unlock" button. Last edited by Octopus box; 12-31-2014 at 12:13. |
01-01-2015, 12:55 | #9 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | @ Octopus box about hold security no probbleme, so Can't read code on new security ? @ gsm@aftab I teste this step next time, so you no root the phone ? and activate debuging ? Best Regards, JAVA Good. |
01-01-2015, 13:47 | #11 (permalink) | |
Junior Member Join Date: Nov 2014
Member: 2295062 Status: Offline Thanks Meter: 1 | Quote:
octoplus/octopus is the best for unlocking GT-I9505.i have done with this. | |
The Following User Says Thank You to cellsolutionbd For This Useful Post: |
