07-13-2017, 17:10 | #92 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mongarrasco
Member: 107027 Status: Offline Thanks Meter: 272 | g928f works great!!!! To connect SM-G928F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-G928F Please put the phone into Download Mode and connect USB cable. Waiting for phone... Reading PIT... PIT was read successfully. Searching for UART interface.. COM11 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Resetting FRP lock.. FRP / Reactivation lock is successfully reseted! Performed by 2.5.6 Software version. that's all! |
The Following User Says Thank You to agentot For This Useful Post: |
07-14-2017, 11:49 | #94 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.6 ----------------------------------------------------------------------------------- ----------------------------------------------------------------------------------- To connect SM-G930F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G930F Please put the phone into Download Mode and connect USB cable. Waiting for phone... Reading PIT... PIT was read successfully. Searching for UART interface.. COM5 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Resetting FRP lock.. FRP / Reactivation lock is successfully reseted! Performed by 2.5.6 Software version. |
07-14-2017, 23:18 | #96 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ESPAÑA
Member: 808967 Status: Offline Thanks Meter: 155 | ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM11 Modelo seleccionado: SM-G930F Please put the phone into Download Mode and connect USB cable. Waiting for phone... Reading PIT... PIT was read successfully. Searching for UART interface.. UART interfaces not found! Operation was failed! Performed by 2.5.6 Software version. |
07-15-2017, 02:29 | #97 (permalink) | |
Freak Poster Join Date: Mar 2016 Location: HUAWEI
Member: 2548753 Status: Offline Thanks Meter: 256 | Quote:
07-15-2017, 09:03 | #102 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan Age: 41
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.6 ----------------------------------------------------------------------------------- To connect SM-G935F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G935F Please put the phone into Download Mode and connect USB cable. Waiting for phone... Reading PIT... PIT was read successfully. Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Resetting FRP lock.. FRP / Reactivation lock is successfully reseted! Performed by 2.5.6 Software version. |
The Following User Says Thank You to Fune4u For This Useful Post: |
07-15-2017, 09:59 | #103 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pAK+Africa
Member: 1190193 Status: Offline Sonork: 1619687 Thanks Meter: 406 | Welcome to Octoplus/Octopus Box Samsung software version 2.5.6 ----------------------------------------------------------------------------------- To connect SM-G935F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G935F Connecting to server... Connecting to server...Ok! Checking resource files... Operation cancelled! Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: SM-G935F Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: SM-G935F Please put the phone into Download Mode and connect USB cable. Waiting for phone... Operation was canceled Performed by 2.5.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: SM-G935F Please put the phone into Download Mode and connect USB cable. Waiting for phone... Reading PIT... PIT was read successfully. Searching for UART interface.. COM33 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Resetting FRP lock.. FRP / Reactivation lock is successfully reseted! Performed by 2.5.6 Software version. |
The Following User Says Thank You to akhtar.abbas For This Useful Post: |
07-16-2017, 06:56 | #105 (permalink) |
No Life Poster Join Date: Mar 2013
Member: 1900730 Status: Offline Thanks Meter: 188 | Bienvenido en Octoplus/Octopus Box Samsung software versión 2.5.6 ----------------------------------------------------------------------------------- To connect SM-G928G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM4 Modelo seleccionado: SM-G928G Please put the phone into Download Mode and connect USB cable. Waiting for phone... Reading PIT... PIT was read successfully. Searching for UART interface.. COM4 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Resetting FRP lock.. FRP / Reactivation lock is successfully reseted! Performed by 2.5.6 Software version. nice, last security patch from 06/17, android 7 NOTE: Make a factory reset or enable OEM Unlock |
The Following User Says Thank You to Maurioski For This Useful Post: |
