05-18-2017, 11:48 | #1 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2617518 Status: Offline Thanks Meter: 2 | n9208dx failed custom binary(userdata) blocked by frp lock and phone stuck an error ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N9208 Reset FRP/ Reactivation lock operation for SM-N9208 will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-N9208 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Writing Firmware Failed Operation was failed! Performed by 2.5.0 Software version. |
05-18-2017, 12:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. Most likely your phone has one of the latest firmwares, in which ability to remove FRP lock with current method was disabled. To restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares. To remove the lock You can try to write older by release date firmware, then repeat the operation. Last edited by Octopus box; 05-18-2017 at 12:14. |
