12-29-2018, 16:01 | #151 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | samsung sm-j500f flash done Code: Selected BOOT file: C:\Users\STONE\Desktop\BL_J500FXXU1BPL1_CL10009322_QB11793049_REV00_user_low_ship_MULTI_CERT.tar.md5 Selected AP file: C:\Users\STONE\Desktop\AP_J500FXXU1BPL1_CL10009322_QB11793049_REV00_user_low_ship_MULTI_CERT.tar.md5 Selected CP file: C:\Users\STONE\Desktop\CP_J500FXXU1BPF3_REV00_CL2117007_QB4815638.tar.md5 Selected CSC file: C:\Users\STONE\Desktop\CSC_OJV_J500FOJV1BPL2_CL10055266_QB11849393_REV00_user_low_ship_MULTI_CERT.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J500F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing QSEE section... QSEE section has been written successfully. Writing QHEE section... QHEE section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing sec section... sec section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing PERSIST section... PERSIST section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.7.7.1 Software version. |
12-29-2018, 16:02 | #152 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | samsung sm-j500f frp unlock done Code: Welcome to Octoplus Box Samsung software version 2.7.7 ----------------------------------------------------------------------------------- To connect SM-J500F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J500F Operation: Reset FRP - UserData Reset FRP/ Reactivation lock operation for SM-J500F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J500F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.7.7.1 Software version. |
12-29-2018, 16:03 | #153 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | samsung sm-a710f flash done Code: Welcome to Octoplus Box Samsung software version 2.7.7 ----------------------------------------------------------------------------------- To connect SM-J510F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Selected AP file: C:\Users\STONE\Desktop\A710FXXU2BQC8_A710FOJV2BQC3_A710FXXU2BQB1_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-A710F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.7.7.1 Software version. |
12-29-2018, 16:42 | #154 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | SM-N920C backup and Repair IMEI successfully done Code: Selected AP file: C:\Users\STONE\Desktop\CF-Auto-Root-noblelte-nobleltejv-smn920c.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-N920C into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.7.7 Software version. Code: Platform: Samsung Android Selected port: COM1 Selected model: SM-N920C Operation: Read security Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-N920C Firmware compiled date: Fri Aug 3 11:42:58 KST 2018 PDA version: N920CXXS5CRH1 CSC version: N920COJV4CRB3 SW version: N920CXXU5JRH1 Phone SN: RF8H502DEFE Android version: 7.0 (NRD90M) Sales code: THR Country: IRAN HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-08-01 Warranty Void: 1 SIM 1 status: absent Codename: nobleltejv Checking Root: Phone is Rooted. Reading security backup, please wait... Security read successfully. Performed by 2.7.7 Software version. Code: Platform: Samsung Android Selected port: COM1 Selected model: SM-N920C Operation: Read EFS Detected phone model: SM-N920C Firmware compiled date: Fri Aug 3 11:42:58 KST 2018 PDA version: N920CXXS5CRH1 CSC version: N920COJV4CRB3 SW version: N920CXXU5JRH1 Phone SN: RF8H502DEFE Android version: 7.0 (NRD90M) Sales code: THR Country: IRAN HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-08-01 Warranty Void: 1 SIM 1 status: absent Codename: nobleltejv Checking Root: Phone is Rooted. Reading EFS, please wait... EFS read successfully. Performed by 2.7.7 Software version. Code: Platform: Samsung Android Selected port: COM1 Selected model: SM-N920C Operation: Read Cert Detected phone model: SM-N920C Firmware compiled date: Fri Aug 3 11:42:58 KST 2018 PDA version: N920CXXS5CRH1 CSC version: N920COJV4CRB3 SW version: N920CXXU5JRH1 Phone SN: RF8H502DEFE Android version: 7.0 (NRD90M) Sales code: THR Country: IRAN HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-08-01 Warranty Void: 1 SIM 1 status: absent Codename: nobleltejv Checking Root: Phone is Rooted. Initializing exploit... Executing exploit... Exploit has been executed successfully Reading Certificate... Checking Certificate file... Phone KeyID: 448 Certificate file successfully checked Certificate read successfully Performed by 2.7.7 Software version. Code: Welcome to Octoplus Box Samsung software version 2.7.7 ----------------------------------------------------------------------------------- To connect SM-N920C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N920C Operation: Repair IMEI A Detected phone model: SM-N920C Firmware compiled date: Fri Aug 3 11:42:58 KST 2018 PDA version: N920CXXS5CRH1 CSC version: N920COJV4CRB3 SW version: N920CXXU5JRH1 Phone SN: RF8H502DEFE Android version: 7.0 (NRD90M) Sales code: THR Country: IRAN HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-08-01 Warranty Void: 1 SIM 1 status: absent Codename: nobleltejv Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N920C-RF8H502DEFE-27-12-2018_17-58-28-.asec file Initializing exploit... Executing exploit... Exploit has been executed successfully New IMEI: xxxxxxxxxxxxxxxx Writing new phone IMEI... Please make "Repair Network" operation after reboot! IMEI successfully repaired. Performed by 2.7.7.1 Software version. Code: Platform: Samsung Android Selected port: COM1 Selected model: SM-N920C Operation: Repair Network Detected phone model: SM-N920C Firmware compiled date: Fri Aug 3 11:42:58 KST 2018 PDA version: N920CXXS5CRH1 CSC version: N920COJV4CRB3 SW version: N920CXXU5JRH1 Phone SN: RF8H502DEFE Android version: 7.0 (NRD90M) Sales code: THR Country: IRAN HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-08-01 Warranty Void: 1 SIM 1 status: absent Codename: nobleltejv Checking Root: Phone is Rooted. Initializing exploit... Executing exploit... Repairing network... Network is successfully repaired. Performed by 2.7.7.1 Software version. Last edited by Octopus box; 12-29-2018 at 16:48. |
12-29-2018, 17:17 | #155 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | SM-A710FD "Repair Network" successfully done Code: Welcome to Octoplus Box Samsung software version 2.7.7 Selected AP file: F:\NEW SAMSUNG FRIMWARE\A710F\A710F ( 7 )\CF-Auto-Root-a7xelte-a7xeltexx-sma710f\CF-Auto-Root-a7xelte-a7xeltexx-sma710f.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-A710FD into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.7.7.1 Software version. Code: Platform: Samsung Android Selected port: COM1 Selected model: SM-A710FD Operation: Repair Network Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-A710F Firmware compiled date: Wed Mar 29 13:58:08 KST 2017 PDA version: A710FXXU2BQC8 CSC version: A710FOJV2BQC3 SW version: A710FXXU2BQB1 Phone SN: RF8H707TCQN Android version: 6.0.1 (MMB29K) Sales code: XSG Country: UAE HW platform: exynos5 HW Chip: exynos7580 HW Modem: SHANNON310 Security patch level: 2017-04-01 Warranty Void: 1 SIM 1 status: ready SIM 2 status: absent Codename: a7xeltexx Checking Root: Phone is Rooted. Checking DaemonSU...OK Repairing network. Please wait, this can take some time... Network is successfully repaired. Performed by 2.7.7.1 Software version. Last edited by Octopus box; 12-30-2018 at 07:51. |
12-29-2018, 19:00 | #156 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | GT-S3802W unlock successfully done Code: Welcome to Octoplus Box Samsung software version 2.7.7 Selected firmware file: S3802WJPMC6_S3802WOJPMC7.oct ----------------------------------------------------------------------------------- Platform: Samsung Infineon Selected model: GT-S3802W Selected port: USB Phone must be OFF, and the battery must be fully charged Please, connect USB cable and reconnect battery. Connecting... Phone found. Sending loaders... Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Writing firmware... Erasing Full Flash... Full Flash erase successfully. Writing "TRON_DS_BSY part 1"... Writing "TRON_DS_BSY" done! Writing "TRON_DS_BSY part 2"... Writing "TRON_DS_BSY" done! Writing "TRON_DS_BSY part 3"... Writing "TRON_DS_BSY" done! Writing "TRON_DS_BSY part 4"... Writing "TRON_DS_BSY" done! Writing "TRON_DS_CDS"... Writing "TRON_DS_CDS" done! Writing "S3802WOJPMC7_CSC_CUST"... Writing "S3802WOJPMC7_CSC_CUST" done! Writing "S3802WOJPMC7_CSC_ROOT"... Writing "S3802WOJPMC7_CSC_ROOT" done! Writing "S3802WOJPMC7_CSC_USER"... Writing "S3802WOJPMC7_CSC_USER" done! Firmware Write successfully. Performed by 2.7.7.1 Software version. Code: To perform this opperation plase select COM port. ----------------------------------------------------------------------------------- Platform: Samsung Infineon Selected model: GT-S3802W Selected port: COM4 Phone must be ON. Searching for a phone. Please wait... Found phone on COM4 Reading info... UniqueNumber : xxxxxxxxxxxxxx SW Version : S3802WJPMC6 Phone IMEI A: xxxxxxxxxxxxxxx Phone IMEI B: xxxxxxxxxxxxxxx Deactivating MSL... MSL deactivate successfully Unlocking phone... Phone is successfully unlocked Please insert card into phone, if phone is locked, then type #0111*00000000# Performed by 2.7.7.1 Software version. Last edited by Octopus box; 12-30-2018 at 07:50. |
The Following User Says Thank You to Moh3en.pc For This Useful Post: |
12-29-2018, 21:58 | #157 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | Samsung T359 read codes and unlock done Welcome to Octoplus Box Samsung software version 2.7.7 Platform: Samsung Anycall Selected port: COM1011 Selected model: SGH-T359 Mode: Normal Phone model: SGH-T359 Firmware compiled date: Nov 13 2009 Firmware compiled time: 10:00:00 Firmware released date: Sep 17 2010 Firmware released time: 12:53:37 Phone IMEI: 35XX27-04-XX43XX-4 SW version: Q6270B-KPVZL-1.5.40T Reading phone unlock codes. This can take some time, please wait... Searching SysInfo, please wait... SysInfo found. Calculating codes. Please wait... FREEZE unlock code: 60250603 NCK unlock code: 41860282 NSCK unlock code: 00000000 SPCK unlock code: 00000000 CPCK unlock code: 00000000 SIM LOCK unlock code: 12369874 Activa LOCK unlock code: 12369874 Work time: 0:03:15 Performed by 2.7.7.1 Software version. Last edited by Octopus box; 12-30-2018 at 07:50. |
The Following User Says Thank You to ThePhoneTechDoc For This Useful Post: |
12-30-2018, 08:44 | #158 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | samsung gt-n7100 imei repair successfully done Code: Welcome to Octoplus Box Samsung software version 2.7.7 ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Selected AP file: F:\NEW SAMSUNG FRIMWARE\N7100 4.4.2\CF-Auto-Root-t03g-t03gxx-gtn7100.tar.md5 Please put the phone into Download Mode and connect USB cable. To put GT-N7100 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.7.7.1 Software version. Code: Platform: Samsung Android Selected port: COM1 Selected model: GT-N7100 Operation: Repair IMEI A Detected phone model: GT-N7100 Firmware compiled date: Mon Mar 3 15:31:59 KST 2014 PDA version: N7100XXUENC1 CSC version: N7100OJVENB1 SW version: N7100XXUENA3 Phone IMEI: 004999010640000 Phone SN: 00000000000 Android version: 4.3 (JSS15J) Sales code: THR Country: UAE HW platform: exynos4 HW Chip: smdk4x12_prime HW Modem: XMM6262 Warranty Void: 1 SIM 1 status: ready Codename: t03gxx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-N7100-Unknown30-12-2018_10-15-59-.asec file Cheking security type... New security type is detected Old IMEI: 004999-01-064000-0 New IMEI: xxxxxxxxxxxxxxxxxxx Repairing IMEI ... Executing exploit... Exploit has been executed successfully Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.7.7.1 Software version. |
12-30-2018, 08:45 | #159 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | samsung sm-j110h flash successfully done Code: Welcome to Octoplus Box Samsung software version 2.7.7 Selected BOOT file: F:\NEW SAMSUNG FRIMWARE\J110H\BL_J110HXXU0AOGA_CL737598_QB5784505_REV02_user_low_ship.tar.md5 Selected AP file: F:\NEW SAMSUNG FRIMWARE\J110H\AP_J110HXXU0AOGA_CL737598_QB5784505_REV02_user_low_ship.tar.md5 Selected CP file: F:\NEW SAMSUNG FRIMWARE\J110H\CP_J110HXXU0AOGA_CL737598_QB5784505_REV02_user_low_ship.tar.md5 Selected CSC file: F:\NEW SAMSUNG FRIMWARE\J110H\CSC_OJV_J110HOJV0AOGB_CL737598_QB5800700_REV02_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J110H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing SBOOT section... SBOOT section has been written successfully. Writing SBOOT2 section... SBOOT2 section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing WDSP section... WDSP section has been written successfully. Writing wfixnv2 section... wfixnv2 section has been written successfully. Writing CSC section... CSC section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.7.7.1 Software version. |
12-30-2018, 08:46 | #160 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | SM-G361H flash successfully done Code: Welcome to Octoplus Box Samsung software version 2.7.7 Selected BOOT file: F:\NEW SAMSUNG FRIMWARE\G361H\BL_G361HXXU0AOG3_CL651165_QB5520846_REV01_user_low_ship.tar.md5 Selected AP file: F:\NEW SAMSUNG FRIMWARE\G361H\AP_G361HXXU0AOG3_CL651165_QB5520846_REV01_user_low_ship.tar.md5 Selected CP file: F:\NEW SAMSUNG FRIMWARE\G361H\CP_G361HXXU0AOF8_CL651165_QB5289227_REV01_user_low_ship.tar.md5 Selected CSC file: F:\NEW SAMSUNG FRIMWARE\G361H\CSC_OJV_G361HOJV0AOG1_CL688459_QB5503667_REV01_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G361H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing SBOOT section... SBOOT section has been written successfully. Writing SBOOT2 section... SBOOT2 section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing WDSP section... WDSP section has been written successfully. Writing wfixnv2 section... wfixnv2 section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.7.7.1 Software version. Last edited by Octopus box; 12-30-2018 at 13:43. |
12-30-2018, 11:10 | #161 (permalink) | |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | J600FN_{Network Lock}_Successfully done.. Full logs of the operation/ Quote:
The Following User Says Thank You to lyes_albert For This Useful Post: |
12-30-2018, 13:07 | #162 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | GT-E1080F Unlock successful done Octoplus Samsung Code: ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E1080F Selected port: COM3 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Searching patch area, please wait... Read codes failed Performed by 2.7.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-E1080F Selected port: COM3 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Searching patch area, please wait... Writing patch... Patch successfully write. Rebooting phone Connecting... Phone in TAT mode. Reading info, please wait... Phone IMEI A: 35869........... SW version: E1080FJPJ Phone SN : RVSB543522 Unlocking phone... All unlock codes were set to 00000000 Phone is successfully unlocked Performed by 2.7.7 Software version. Last edited by Octopus box; 12-30-2018 at 13:50. |
The Following User Says Thank You to naveedullah0044 For This Useful Post: |
12-30-2018, 14:58 | #163 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | samsung SM-J710GN unlock successful done Code: Welcome to Octoplus Box Samsung software version 2.7.5 ----------------------------------------------------------------------------------- To connect SM-J710GN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM466 Selected model: SM-J710GN Operation: Read Codes - Modem port Searching for a phone. Please wait... Found phone on COM466 Reading info... Detected phone model: SM-J710GN HW Version: SM-J710GZDUXME PDA version: J710GNDXU1API5 CSC version: J710FOJV1API1 CP version: J710GNDXU1API1 Phone SN: RF8HC1ZF9WD Phone IMEI: xxxxxxxxxxxxxx Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 64961718 NET LOCK unlock code: 96142950 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:39 Performed by 2.7.5 Software version. |
12-30-2018, 15:45 | #164 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | GT-S3770 Reading codes successfully DONE Code: ----------------------------------------------------------------------------------- Platform: Samsung Swift Selected model: GT-S3770 Selected port: COM4 Baud rate: 115200 Plase, connect phone to UART cable, insert battery and press shortly power button Connecting... Phone in TAT mode. Reading info, please wait... Phone IMEI A: XXXXXXXXXXXXXXXXX SW version: S3770JPKJ Reading codes... FREZEE : 89262370 NET LOCK : 00000000 Subset LOCK : 00000000 SP LOCK : 00000000 CP LOCK : 00000000 SIM LOCK : 11111372 Activa LOCK : 00000000 Phone LOCK : 00000000 Reading codes successfully completed. Performed by 2.7.7.1 Software version. Last edited by Octopus box; 12-31-2018 at 08:57. |
12-30-2018, 16:52 | #165 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | SM-J510F Reset FRP successfully DONE Code: Welcome to Octoplus Box Samsung software version 2.7.7 ----------------------------------------------------------------------------------- To connect SM-J510F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J510F Operation: Reset FRP - UserData Reset FRP/ Reactivation lock operation for SM-J510F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.7.7.1 Software version. Last edited by Octopus box; 12-31-2018 at 08:58. |
