12-16-2018, 13:14 | #61 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | J106 frp reset done SAMSUNG J1 MINI J106 FRP RESET DONE Welcome to Octoplus Box Samsung software version 2.6.7 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J106H Operation: Reset FRP - UserData Reset FRP/ Reactivation lock operation for SM-J106H will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J106H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.7 Software version. |
The Following User Says Thank You to taimur-ahmad For This Useful Post: |
12-16-2018, 13:17 | #62 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Samsung j320 frp reset done SAMSUNG J320 FRP RESET DONE Welcome to Octoplus Box Samsung software version 2.6.8 ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J320F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J320F Operation: Reset FRP - UserData Reset FRP/ Reactivation lock operation for SM-J320F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Could not connect to the server! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J320F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.8.2 Software version. |
12-16-2018, 13:23 | #63 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Samsung j320v frp reset done SAMSUNG J320V FRP RESET DONE ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J320V Operation: Reset FRP - UserData Reset FRP/ Reactivation lock operation for SM-J320V will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-J320V into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.7 Software version. |
The Following 2 Users Say Thank You to taimur-ahmad For This Useful Post: |
12-16-2018, 13:25 | #64 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Samsung SM-J710F Reset FRP successfully done Samsung SM-J710F Reset FRP successfully done Code: Welcome to Octoplus Box Samsung software version 2.6.7 ----------------------------------------------------------------------------------- To connect SGH-I727 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090# or *#0808#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G925T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925T Operation: Repair Security Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-G925T Firmware compiled date: Wed Jan 10 17:34:43 KST 2018 PDA version: G925TUVS6FRA3 CSC version: G925TTMB6FRA3 SW version: G925TUVS6FRA3 Android version: 7.0 (NRD90M) Sales code: TMB Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-01-01 SIM 1 status: absent Codename: zeroltetmo Wiping EFS... Phone will restart now. Please don't disconnect cable! EFS wipe successfully Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925T Operation: Write EFS Detected phone model: SM-G925T Firmware compiled date: Wed Jan 10 17:34:43 KST 2018 PDA version: G925TUVS6FRA3 CSC version: G925TTMB6FRA3 SW version: G925TUVS6FRA3 Android version: 7.0 (NRD90M) Sales code: TMB Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-01-01 SIM 1 status: absent Codename: zeroltetmo Checking Root: Phone is Rooted. Writing EFS, please wait... Phone will restart now. Please don't disconnect cable! EFS write successfully. Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925T Operation: Write Cert Selected file: J:\Z3X\G925T\all\cert-sm-g925t-359715060542685.cert Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SM-G925T Firmware compiled date: Wed Jan 10 17:34:43 KST 2018 PDA version: G925TUVS6FRA3 CSC version: G925TTMB6FRA3 SW version: unknown Android version: 7.0 (NRD90M) Sales code: TMB Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Security patch level: 2018-01-01 SIM 1 status: not ready Codename: zeroltetmo Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G925T--16-04-2018_22-21-14-.asec file Checking Certificate file... Certificate file successfully checked Initializing exploit...OK Executing exploit... Executing exploit failed Initializing exploit... Executing exploit... Exploit has been executed successfully Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925T Operation: Repair Security Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SM-G925T Firmware compiled date: Wed Jan 10 17:34:43 KST 2018 PDA version: G925TUVS6FRA3 CSC version: G925TTMB6FRA3 SW version: unknown Phone SN: R58G31M6JRE Android version: 7.0 (NRD90M) Sales code: TMB Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: unknown Security patch level: 2018-01-01 SIM 1 status: not ready Codename: zeroltetmo Wiping EFS... Phone will restart now. Please don't disconnect cable! EFS wipe successfully Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SM-G925T To put SM-G925T into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G925T Operation: Write Cert Selected file: J:\Z3X\G925T\all\cert-sm-g925t-359146060454970- r58g40hj2pm.cert Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SM-G925T Firmware compiled date: Wed Jan 10 17:34:43 KST 2018 PDA version: G925TUVS6FRA3 CSC version: G925TTMB6FRA3 SW version: G925TUVS6FRA3 Phone SN: RF1D45EJGGR Android version: 7.0 (NRD90M) Sales code: TMB Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-01-01 SIM 1 status: absent Codename: zeroltetmo Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G925T-RF1D45EJGGR-16-04-2018_22-39- 44-.asec file Checking Certificate file... Certificate file successfully checked Initializing exploit...OK Executing exploit... Executing exploit failed Initializing exploit... Executing exploit... Exploit has been executed successfully Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- To connect SM-G900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Operation: Reset FRP - UART EMMC Searching for UART interface.. Found more then one box connected to COM7 COM7 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation... This version of "sBoot" is not supported, try to downgrade "sBoot"! Operation was failed! Performed by 2.6.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)... Please, press "OK" button on the phone to allow USB debugging. Reading info... Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SM-J710F Firmware compiled date: Tue Nov 28 14:47:17 KST 2017 PDA version: J710FXXU3BQK8 CSC version: J710FOJV3BQJ2 SW version: J710FXXU3BQJ5 Phone SN: RF8J31N721V Android version: 7.0 (NRD90M) Sales code: KSA Country: KSA HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2017-08-01 SIM 1 status: absent SIM 2 status: absent Codename: j7xeltexx Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.6.7 Software version. Last edited by Octopus box; 12-17-2018 at 06:17. |
12-17-2018, 13:00 | #65 (permalink) | |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | SM-G903W_{Factory Reset Protection}_Successfully Removed... Full logs of the operation Quote:
The Following 2 Users Say Thank You to lyes_albert For This Useful Post: |
12-17-2018, 14:17 | #66 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Samsung GT-E1050 Reading codes... done Samsung GT-E1050 Reading codes... done Platform: Samsung Swift Selected model: GT-E1050 Selected port: COM3 Baud rate: 115200 Please, connect phone to UART cable, insert battery and press power button for 3 seconds. Phone found. Sending preloader... Preloader send successfully Reading flash memory parameters.. Setting baudrate.. Sending mainloader... Mainloader send successfully Searching patch area, please wait... Writing patch... Patch successfully write. Rebooting phone Connecting... Phone in TAT mode. Reading info, please wait... Phone IMEI A: 35957904091166 SW version: E1050AOKF Phone SN : RPABB11886 Reading codes... FREZEE: 47563710 NET LOCK: 96817340 Subset LOCK: 96817340 SP LOCK: 00000000 CP LOCK: 00000000 SIM LOCK: 00000000 Activa LOCK: 00000000 User LOCK: 00015555 Performed by 2.7.7 Software version. Thanks Octopus team |
The Following 2 Users Say Thank You to pintu_das For This Useful Post: |
12-17-2018, 16:08 | #67 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | SM-J320A (6.0.1) "Read Codes" successfully done w/out root and w/out tripping KNOX SM-J320A (6.0.1) "Read Codes" successfully done w/out root and w/out tripping KNOX: Code: Platform: Samsung Android Selected port: COM861 Selected model: SM-J320A Operation: Read info Reading info, please wait... Detected phone model: SM-J320A Firmware compiled date: Mon Jan 23 20:31:27 KST 2017 PDA version: J320AUCS2AQA1 CSC version: J320AATT3AQG1 SW version: J320AUCU3AQD1 Phone SN: R28HA2Z6HCY Android version: 6.0.1 (MMB29K) Sales code: ATT Country: USA HW platform: exynos3 HW Chip: exynos3475 HW Modem: SHANNON308 Security patch level: 2017-01-01 Warranty Void: 0 SIM 1 status: absent Codename: j3xlteuc Performed by 2.7.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM861 Selected model: SM-J320A Operation: Read Codes - Modem port Searching for a phone. Please wait... Found phone on COM861 Reading info... Detected phone model: SM-J320A HW Version: SM2J320AZWAATT PDA version: J320AUCS2AQA1 CSC version: J320AATT3AQG1 CP version: J320AUCU3AQD1 Phone SN: R28HA2Z6HCY Phone IMEI: 355022-07-399907-5 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 70462617 NET LOCK unlock code: 06208031 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:01:25 Performed by 2.7.7 Software version. Last edited by Octopus box; 12-17-2018 at 16:24. |
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
12-17-2018, 21:31 | #68 (permalink) |
Member: 75408 Status: Offline Thanks Meter: 1,190 | SM-G925F (G925FXXU6ERF6, 7.0) "Read Codes" successfully done SM-G925F (G925FXXU6ERF6, 7.0) "Read Codes" successfully done: Code: Platform: Samsung Android Selected port: COM958 Selected model: SM-G925F Operation: Read Codes Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-G925F Firmware compiled date: Wed Jun 20 16:33:32 KST 2018 PDA version: G925FXXU6ERF5 CSC version: G925FEVR6ERF2 SW version: G925FXXU6ERF6 Phone SN: R58GB0W89HZ Android version: 7.0 (NRD90M) Sales code: EVR Country: UK HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2018-06-01 Warranty Void: 0 SIM 1 status: absent Codename: zeroltexx Checking Root: Phone is Rooted. Initializing exploit...OK Executing exploit...OK Exploit has been executed successfully Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 37313157 NET LOCK unlock code: 24097135 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:02:11 Performed by 2.7.7 Software version. Last edited by Octopus box; 12-17-2018 at 21:55. |
12-17-2018, 22:44 | #69 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Arusha,Tanzania
Member: 2267293 Status: Offline Thanks Meter: 79 | Successful unlocked SM-J727T1 (instructions inside) Very Cool, A lot of thanks to OCTOPLUS TEAM For Their Hard Working... NOTE: PLEASE DO NOT IGNORE THIS INSTRUCTION <<<Take out SIM card from phone.>>> It made me suffer and repeat operation over and over and the phone is unlocked but still says locked after restarted, When i remembered to remove the SIMCARD and repeat the operation then after unlocking i turned it off and insert back the simcard and then everything went fine. Log. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM42 Selected model: SM-J727T1 Operation: Unlock Detected phone model: SM-J727T1 Firmware compiled date: Tue Aug 14 23:40:32 KST 2018 PDA version: J727T1UVU3BRH3 CSC version: J727T1TMK3BRH3 SW version: J727T1UVU3BRH3 Phone SN: R28K81EY9WV Android version: 8.1.0 (M1AJQ) Sales code: TMK Country: USA HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2018-06-01 Warranty Void: 0 SIM 1 status: absent Codename: j7popeltemtr Connecting to modem port... Found phone on COM42 Reading IMEI...OK ----------------------------------------------------------------------------------- Connecting to server...OK Checking smart card...OK Username: madcom5 Authorizing...OK Checking balance...OK Checking operation...OK Your balance: 0 credits. ----------------------------------------------------------------------------------- Sending device information...OK Checking operation...OK Initializing exploit...OK Initializing... Reading HWID...OK Initializing exploit...OK Unlocking phone...OK Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.7.7 Software version. Thanks to OCTOPLUS TEAM... Last edited by Octopus box; 12-18-2018 at 05:30. |
The Following 2 Users Say Thank You to madcom5 For This Useful Post: |
12-17-2018, 23:41 | #70 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | SM-G960U Sprint successfully unlocked Welcome to Octoplus Box Samsung software version 2.7.7 ----------------------------------------------------------------------------------- Connecting to server... Username: amin******** Authorizing... Checking balance... Your balance: ******** credits. Performed by 2.7.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SM-G960U Operation: Unlock Searching for a phone. Please wait... Detected phone model: SM-G960U Firmware compiled date: Thu Sep 6 14:03:10 KST 2018 PDA version: G960USQS3ARI4 CSC version: G960UOYN3ARI4 SW version: G960USQU3ARG2 Phone SN: R58KA0ZZ2GY Android version: 8.0.0 (R16NW) Sales code: SPR Country: USA HW platform: sdm845 HW Chip: SDM845 HW Modem: SDM845 Security patch level: 2018-09-01 Warranty Void: 0 SIM 1 status: card io error Codename: starqltesq Connecting to modem port... Found phone on COM18 Reading IMEI...OK ----------------------------------------------------------------------------------- Connecting to server...OK Checking smart card...OK Username: amin******* Authorizing...OK Checking balance...OK Checking operation...OK Your balance: ****** credits. ----------------------------------------------------------------------------------- Sending device information...OK Initializing exploit...OK Checking lock status...Locked Reading data from phone...OK Searching for USB diagnostic port... Reading info... Mode: Normal Firmware compiled date: May 11 2018 Firmware compiled time: REV1.1 Firmware released date: Jul 11 2018 Firmware released time: 16:10:55 SW Version: MPSS.AT.4.0.c2.5-00045-SDM845_GEN_PACK-1.135721.3.150178.1 Reading data...OK Unlocking phone...OK Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.7.7 Software version. Last edited by Octopus box; 12-18-2018 at 05:31. |
The Following 2 Users Say Thank You to Dzomega For This Useful Post: |
12-17-2018, 23:54 | #71 (permalink) |
Member: 2581848 Status: Offline Thanks Meter: 249 | Another one SM-G960U Sprint unlocked ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM19 Selected model: SM-G960U Operation: Unlock Searching for a phone. Please wait... Detected phone model: SM-G960U Firmware compiled date: Thu Sep 6 14:03:10 KST 2018 PDA version: G960USQS3ARI4 CSC version: G960UOYN3ARI4 SW version: G960USQU3ARG2 Phone SN: R58KA0ZYALE Android version: 8.0.0 (R16NW) Sales code: SPR Country: USA HW platform: sdm845 HW Chip: SDM845 HW Modem: SDM845 Security patch level: 2018-09-01 Warranty Void: 0 SIM 1 status: card io error Codename: starqltesq Connecting to modem port... Found phone on COM20 Reading IMEI...OK ----------------------------------------------------------------------------------- Connecting to server...OK Checking smart card...OK Username: amin******* Authorizing...OK Checking balance...OK Checking operation...OK . ----------------------------------------------------------------------------------- Sending device information...OK Initializing exploit...OK Checking lock status...Locked Reading data from phone...OK Searching for USB diagnostic port... Reading info... Mode: Normal Firmware compiled date: May 11 2018 Firmware compiled time: REV1.1 Firmware released date: Jul 11 2018 Firmware released time: 16:10:55 SW Version: MPSS.AT.4.0.c2.5-00045-SDM845_GEN_PACK-1.135721.3.150178.1 Reading data...OK Unlocking phone...OK Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.7.7 Software version. Last edited by Octopus box; 12-18-2018 at 05:33. |
12-18-2018, 09:40 | #72 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | SM-A710K Reset FRP successfully done Welcome to Octoplus Box Samsung software version 2.7.5 ----------------------------------------------------------------------------------- To connect SM-G9350 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A710K Operation: Reset FRP - UART EMMC Searching for UART interface.. COM8 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM8 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Searching for UART interface.. COM8 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock..success FRP / Reactivation lock is successfully reseted! Performed by 2.7.5 Software version. Last edited by Octopus box; 12-18-2018 at 09:51. |
The Following 2 Users Say Thank You to lerner_ For This Useful Post: |
12-18-2018, 19:05 | #73 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | Samsung GT-I9300 Repair IMEI successfully done Code: Welcome to Octoplus Box Samsung software version 2.7.7 ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9300 Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Detected phone model: GT-I9300 Firmware compiled date: Sat Oct 26 12:29:22 KST 2013 PDA version: I9300XXUGMJ9 CSC version: I9300VFGGMJ5 SW version: I9300BUUGMJ3 Phone IMEI: XXXXXXXXXXXXX Phone SN: RZ1DB3Z500V Android version: 4.3 (JSS15J) Sales code: VD2 Country: Germany HW platform: exynos4 HW Chip: exynos4412 HW Modem: unknown SIM 1 status: absent Codename: m0xx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9300-Unknown18-12-2018_21-28-21-.asec file Cheking security type... New security type is detected Old IMEI: XXXXXXXXXXXXXXX New IMEI: XXXXXXXXXXXXXXX Repairing IMEI ... Executing exploit... Exploit has been executed successfully Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.7.7 Software version. Last edited by Octopus box; 12-19-2018 at 06:51. |
12-18-2018, 19:09 | #74 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | GT-I9300 enabling all language done Code: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Sat Oct 26 12:29:22 KST 2013 PDA version: I9300XXUGMJ9 CSC version: I9300VFGGMJ5 SW version: I9300BUUGMJ3 Phone IMEI: XXXXXXXXXXXXX Phone SN: RZ1DB3Z500V Android version: 4.3 (JSS15J) Sales code: VD2 Country: Germany HW platform: exynos4 HW Chip: exynos4412 HW Modem: unknown SIM 1 status: absent Codename: m0xx Checking Root: Phone is Rooted. Updating languages.. Phone will restart now. Please don't disconnect cable! All hidden languages was successfully enabled. Performed by 2.7.7 Software version. Last edited by Octopus box; 12-19-2018 at 06:53. |
