Problem unlock i8160 Hi I'm trie unlock I8160, the octopus suite all Bienvenido en Octopus Box Samsung software versión 1.9.0 ----------------------------------------------------------------------------------- To connect GT-I8160 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM22 Modelo seleccionado: GT-I8160 Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Wed Dec 21 10:03:08 KST 2011 IMEI del teléfono: 35847204984xxxx Phone SN: 00000000000 Android version: 2.3.6 (GINGERBREAD) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM22 Modelo seleccionado: GT-I8160 Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Wed Dec 21 10:03:08 KST 2011 IMEI del teléfono: 35847204984xxxx Phone SN: 00000000000 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Reading data from phone... Can't root Android version 2.3.6 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. La liberación del teléfono ha sido fallada ----------------------------------------------------------------------------------- To connect GT-I9003 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Close window. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM22 Modelo seleccionado: GT-I9003 ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM36 Modelo del teléfono detectado: GT-I9003 Versión del HW: GT-I9003MKDXEC IMEI del teléfono: 358472-04-984xxxx Fecha de creación del firmware: Wed Dec 21 10:03:08 KST 2011 IMEI del teléfono: 35847204984xxxx Phone SN: 00000000000 Android version: 2.3.6 (GINGERBREAD) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM36 Modelo seleccionado: GT-I9003 Searching for a phone. Please wait... Detect Model Name: GT-I9003 S/W version: I9003BGKP7 Phone found. If Screen lock removed and phone not found by software then do next steps: Go to Menu->Settings->Applications->Development. Turn on "USB Debugging" option. When message is appear press "Yes". Searching for a phone. Please wait... Fecha de creación del firmware: Wed Dec 21 10:03:08 KST 2011 IMEI del teléfono: 35847204984xxxx Phone SN: 00000000000 Android version: 2.3.6 (GINGERBREAD) Detecting Screen Lock parameters... Can't root Android version 2.3.6 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM36 Modelo seleccionado: GT-I9003 Modelo del teléfono detectado: GT-I9003 Versión del HW: GT-I9003MKDXEC IMEI del teléfono: 358472-04-984xxxx Fecha de creación del firmware: Wed Dec 21 10:03:08 KST 2011 IMEI del teléfono: 358472049846032 Phone SN: 00000000000 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Can't root Android version 2.3.6 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. La liberación del teléfono ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM36 Modelo seleccionado: GT-I9003 Modelo del teléfono detectado: GT-I9003 Versión del HW: GT-I9003MKDXEC IMEI del teléfono: 358472-04-984xxxx Fecha de creación del firmware: Wed Dec 21 10:03:08 KST 2011 IMEI del teléfono: 358472049846032 Phone SN: 00000000000 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Realizando el backup de NVM Backup saved as C:\Program Files\GsmServer\OctopusSamsung \BACKUP\NVDATA-GT-I9003-358472049846032-01-05-2013_19-34- 07-.nvm file Unlocking phone. It can take some time. Please wait... El teléfono se reiniciará ahora El teléfono ha sido liberado con éxito El teléfono se reiniciará ahora ----------------------------------------------------------------------------------- To connect GT-I8160 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: GT-I8160 Searching for a phone. Please wait... Phone found. Fecha de creación del firmware: Thu May 3 17:39:01 KST 2012 Android version: 2.3.6 (GINGERBREAD) Liberando el teléfono... Reading data from phone... Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... Phone found. Unlocking phone. It can take some time. Please wait... Please insert card into phone, if phone is locked, then type 00000000 El teléfono ha sido liberado con éxito And now not accept any sim card |
Hello. Please carefully read software log: Quote:
Thank you for your help. |
