Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 05-14-2018, 05:45   #1 (permalink)
Member: 1283129
Thanks Meter: 135
Remove FRP question on SM-N920A bit 5 and SM-G930A bit 4 question [Answered]
Hello,
Sorry I haven't been doing Samsung for a year so I am rusty.
I have some N920A and G930A phones. To remove this FRP usually flash combination (make sure don't upgrade to higher bit firmware). Then it boots to combination OS with ADB, you go remove FRP, then reset and reload stock and profit.
I have some similar problems (N920A is on 5ERD1 and G930A is on 4BRC1)
I flash combination to N920 it just stays on the loadup screen, it detects ADB and I can remove FRP but it never gets to the main screen so I can reset.
I flash combination to the G930A it fails (wrong size xxx>xxx....). If I flash only boot.bin it only blink samsung screen. I think this bit 4 combo file is bad because I flash to a few phones and it fails?
COMBINATION_FA60_G930AUCU4AQG1_CL7396706_QB1429958 2_REV02.oct
(the same combo file other versions fails too on many G930a phones I think this is a bad file)
Has anyone been able to remove FRP N920A bit5, or G930A bit4?
Did anyone have success removing FRP on these models with this new firmware?
Sorry if a stupid question but these are new firmware versions. I'm a willing test dummy =)
Old 05-14-2018, 07:44   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: N/A
Thanks Meter: 27,576
Hello.
Please always read Software manual ("Help" button in Software) on which reset FRP methods are supported and on how to perform the operation.
To reset FRP on SM-N920A no need to use Combination firmware, You can reset FRP via Samsung micro UART cable - just press "Reset FRP / Reactivation"->"Via UART (UFS memory chip)" and follow Software instructions (prompts). Then post here the result.
To reset FRP on SM-G930A You can use ENG boot instead of writing Combination firmware:
Method 2. Via ADB (ENG root)
1. Enable ADB and Root then phone by writing boot partition from engineering firmware
2. Click "Reset FRP / Reactivation" button.
3. Connect the phone to PC via Micro USB cable.
4. Follow software instructions (prompts).
ENG boot for SM-G930A You can find on the Support Area.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 05-14-2018, 07:47   #3 (permalink)
choksi's Avatar
Member: 2783412
Sonork: 1680285
Thanks Meter: 229
why dont you use ""RESET FRP UFS"" method??
2 second job, no need combi or flash
The Following 3 Users Say Thank You to choksi For This Useful Post:
Page generated in 0.11259 seconds with 9 queries
