01-14-2016, 10:20 | #1 (permalink) |
Registered User Join Date: Oct 2000 Location: CI Age: 44
Member: 2246 Status: Offline Thanks Meter: 20 | About T807v cp logging! original firmware&recovery Already enable cp logging in recovery mode (+30012012732+ ok *#0808# nothing happens *#7284# nothing happens *#9090# nothing happens *#66336# nothing happens thanks! |
01-14-2016, 17:18 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Try to do the next: 1. Open Dialer enter *#22745927 2. When Enable/Disable Menu comes up tap "Hidden Menu Disabled" 3. Select "Enable" on Popup 4. Press Home button 5. Open Dialer 6. Dial **87284 7. When PhoneUtil Opens Select PDA 8. Tap Qualacomm USB Setting 9. Select DM+Modem+ADB 10. Tap OK |
01-15-2016, 09:55 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | You can try to root the tab with the latest versions of IRoot and Kingo Root tools. |
