Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 02-10-2014, 12:49   #1 (permalink)
samirr's Avatar
Member: 179229
Thanks Meter: 14
S6790 dead after unlock!!!?
Dear team octoplus i unlock one sam s6790 after unlock procedure phone is totaly dead no boot no download mode.please any help to sove thias problem???
Best regards.
Old 02-10-2014, 12:52   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,124
Hello.
Post here full Software log with the procedure of writing the special firmware and ""Unlock" operation.
Old 02-10-2014, 14:05   #3 (permalink)
samirr's Avatar
Member: 179229
Thanks Meter: 14
HI! HERE IS LOG FOR FLASHING AND UNLOCKING OPERATION:
FLASHING:
Selected firmware file: GT-S6790_for_Unlock_and_SN_Repair.oct
WARN : 08/02/2014 20:17:25 > Please switch your phone to the download mode and connect it to a PC.
WARN : 08/02/2014 20:17:25 > To put GT-S6790 phone into download mode you have to perform the following steps:
WARN : 08/02/2014 20:17:25 > 1. Reconnect phone battery.
WARN : 08/02/2014 20:17:25 > 2. Press and hold "Volume - " + "Home" + "Power" buttons.
WARN : 08/02/2014 20:17:25 > 3. When phone turns on press "Volume+" button.
INFO : 08/02/2014 20:17:25 > Found phone on
INFO : 08/02/2014 20:17:25 > Firmware write started.
INFO : 08/02/2014 20:17:27 > Writing SBL1 section...
INFO : 08/02/2014 20:17:30 > SBL1 section has been written successfully.
INFO : 08/02/2014 20:17:30 > Writing KERNEL section...
INFO : 08/02/2014 20:17:33 > KERNEL section has been written successfully.
INFO : 08/02/2014 20:17:33 > Writing RECOVERY section...
INFO : 08/02/2014 20:17:37 > RECOVERY section has been written successfully.
INFO : 08/02/2014 20:17:37 > Writing modem section...
INFO : 08/02/2014 20:18:27 > modem section has been written successfully.
INFO : 08/02/2014 20:18:27 > Writing CSC section...
INFO : 08/02/2014 20:18:40 > CSC section has been written successfully.
INFO : 08/02/2014 20:18:40 > Writing system section...
INFO : 08/02/2014 20:22:39 > system section has been written successfully.
INFO : 08/02/2014 20:22:39 > Writing HIDDEN section...
INFO : 08/02/2014 20:22:55 > HIDDEN section has been written successfully.
INFO : 08/02/2014 20:22:55 > Writing DTS section...
INFO : 08/02/2014 20:22:58 > DTS section has been written successfully.
INFO : 08/02/2014 20:22:58 > Writing PARAM section...
INFO : 08/02/2014 20:23:01 > PARAM section has been written successfully.
INFO : 08/02/2014 20:23:01 > Firmware writing successfully completed.
UNLOCKING LOG:
Platform: Samsung Broadcom
INFO : 08/02/2014 20:27:45 > Selected port: COM229
INFO : 08/02/2014 20:27:45 > Selected model: GT-S6790
INFO : 08/02/2014 20:27:46 > Connecting to phone on COM230
WARN : 08/02/2014 20:27:48 > Phone connection failed
INFO : 08/02/2014 20:27:48 > Connecting to phone on COM229
INFO : 08/02/2014 20:27:50 > Detected phone model: GT-S6790
INFO : 08/02/2014 20:27:51 > Firmware compiled date: Mon Sep 9 18:48:30 KST 2013
INFO : 08/02/2014 20:27:52 > Phone SN: RV1DB5787VE
INFO : 08/02/2014 20:27:52 > Android version: 4.1.2 (JZO54K)
INFO : 08/02/2014 20:27:52 > Unlocking phone...
INFO : 08/02/2014 20:27:58 > Phone is successfully unlocked
INFO : 08/02/2014 20:27:58 > Please, restart the phone to apply changes.
BEST REGARDS
Old 02-10-2014, 14:17   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
This is strange. "Unlock" operation doesn't affect phone's boot loaders. Please try to fully charge phone's battery with external charger and put the phone into Download Mode again (reconnect the battery, press and hold "Volume-" + "Power ON" buttons).
Old 02-27-2014, 00:09   #5 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
mine dead too after unlock
Welcome to Octoplus/Octopus Box Samsung software version 1.4.9
To connect GT-I9000 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "USB" radio button to "PDA" value.
8. Close window.
9. Go to dial window.
10. Enter "*#9090#" number.
11. Set "Diag config" to "USB" value.
12. Restart phone.
13. Press "Read Info" in software.
Selected port: COM1
Phone was not found on the selected port!
Selected port: COM1
Connecting to phone on COM112
PC.
following steps:
Found phone on
Selected port: COM1
Connecting to phone on COM108
Phone SN: RV1DB5FFNFJ
Unlocking phone...
Old 02-27-2014, 00:10   #6 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
what should i do now
and there is no tool can repair it
Old 02-27-2014, 07:43   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
As I have said above, "Unlock" operation doesn't affect phone's boot loaders. Try to fully charge phone's battery with external charger and put the phone into Download Mode again (reconnect the battery, press and hold "Volume-" + "Power ON" buttons).
Anyway, we will research the problem and write You the result.
Old 02-27-2014, 22:13   #8 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
sir i m using power supply and i changed many batteries ,i guess i need to buy a new cellphone for the customers
LordMen007
Old 02-27-2014, 22:15   #9 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
the problem is that no jtag box support this fone
Old 02-28-2014, 07:53   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Now we research the problem. Also we will try to add support for this device to Octoplus Jtag and Medusa in future updates.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.28275 seconds with 7 queries
