Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 11-03-2016, 08:00   #1 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 64
s7582 big problem
flash ok repair files flash but no repair imie no repair network set root ok with iroot but no any opration plz help
set condition no network found
Old 11-03-2016, 08:31   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,376
Hello.
After what actions with the phone problem occurred? Please post here full Software logs of performed operations.
Please make "Repair Network", then try to find and select Network manually. Post here the result.
Old 11-03-2016, 13:47   #3 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 64
Welcome to Octoplus/Octopus Box Samsung software version 2.4.1
To connect GT-S7582 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3. Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#7284#" number.
8. Set "UART" radio button to "MODEM" value.
9. Set "USB" radio button to "PDA" value.
10. Press "Save and Reset", phone will restart.
11. Press "Read Info" in software.
Selected firmware file: GT-S7582_for_Unlock_and_IMEI_SN_Repair.oct
Platform: Samsung Android
Selected port: COM1
Selected model: GT-S7582
Please, press "OK" button on the phone to allow USB debugging..
Detected phone model: GT-S7582
Firmware compiled date: Thu Aug 28 23:25:49 KST 2014
PDA version: S7582XXUANH3
CSC version: S7582OJVANI1
SW version: S7582XXUANG1
Phone IMEI: 355022060870412
Phone SN: R51FB209PTB
Android version: 4.2.2 (JDQ39)
Sales code: XSG
Country: UAE
HW platform: hawaii
HW Chip: hawaii
HW Modem: unknown
Codename: kyleprodsxx
Rebooting phone in Download Mode...
Phone successfully rebooted in Download Mode.
Performed by 2.4.1 Software version.
Please put the phone into Download Mode and connect USB cable.
To put GT-S7582 into Download Mode, You have to perform the
following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Found phone on
Firmware write started.
Writing KERNEL section...
KERNEL section has been written successfully.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing modem section...
modem section has been written successfully.
Writing DTS section...
DTS section has been written successfully.
Writing CSC section...
CSC section has been written successfully.
Writing system section...
system section has been written successfully.
Writing HIDDEN section...
HIDDEN section has been written successfully.
Writing PARAM section...
PARAM section has been written successfully.
Firmware writing successfully completed.
Platform: Samsung Broadcom
Selected port: COM1
Connecting to phone on COM48
ADB server killed.
Firmware compiled date: Mon Nov 11 09:48:03 KST 2013
Checking Root:
Please, press "Allow" button on the phone if it's need.
Can't root Android version 4.2.2 and higer. Please Root the phone, or
flash phone using firmware with lower version of Android or rooted
firmware and repeat operation.
Can't get root privileges.
Repairing network failed.
Selected port: COM48
SW version:
S7582XXUAMK3/S7582OJVAMJ2/S7582XXUANG1/S7582XXUAMK3
HW Version: GT-S7582ZKAXSG
Phone IMEI A: 355022-06-087041-2
Proper android device not found. Make shure that "USB debug" option
on the device is turned on.
Port is busy
Connecting to phone on COM47
Port is busy
Phone was not found on the selected port!
SW version:
Can't kill external ADB references. Please, close all programs that use
ADB server.
Checking Root:
same problem download oct file reapir imie file from suport but same
Old 11-03-2016, 14:10   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
As You can see from Software log, phone's modem part is damaged, which is most likely:
HW Modem: unknown
Most likely this is the reason for problems with Network. Damaged modem part can be Software (modem firmware or EFS is damaged, or You have written unsuitable firmware) or HW problem.
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown).
"Repair Network" operation requires phone to be rooted:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12243 seconds with 7 queries
