Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 04-04-2015, 19:48   #1 (permalink)
Member: 2356430
Thanks Meter: 7
SC-01G done unlocking using octopus 1.9.1
many thanks to octopus team....
The Following User Says Thank You to myk143 For This Useful Post:
Old 04-04-2015, 21:11   #2 (permalink)
Member: 2356430
Thanks Meter: 7
Welcome to Octoplus/Octopus Box Samsung software version 1.9.1
To connect SC-01G phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM10
Selected model: SC-01G
Reading info, please wait...
Detected phone model: SC-01G
Firmware compiled date: Sat Oct 4 20:51:37 KST 2014
PDA version: SC01GOMU1ANJ3
CSC version: SC01GDCM1ANJ3
SW version: SC01GOMU1ANJ3
Phone IMEI: Unknown
Android version: 4.4.4 (KTU84P)
Phone IMEI: Unknown
Reading info...
Mode: Normal
Firmware compiled date: Sep 15 2014
Firmware compiled time: 17:00:00
Firmware released date: Oct 3 2014
Firmware released time: 23:25:46
SW Version: MPSS.DI.3.0.c5-00272-M9625TAARANAZM-1
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung
\BACKUP\QCN-SC-01G-05-04-2015_01-15-30-.qcn file
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
\BACKUP\Security-SC-01G-05-04-2015_01-15-31-.asec file
Wiping EFS...
Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha
\Cert-SM-N915_355072060300852.cert
Perform the following steps:
1. Connect phone via UART cable to the Box.
2. Note: phone screen must be active
Connecting to phone, please wait...
Writing Certificate failed
To connect SM-N915D phone you have to perform the following steps:
13. Restart phone.
Selected model: SM-N915D
\Cert-SM-N910-354483061000006.cert
13. Restart phone.
Proper android device not found. Make shure that "USB debug" option
on the device is turned on.
Selected port: COM1
Selected port: COM1
Selected port: COM1
Selected port: COM1
Selected port: COM1
Selected port: COM1
Selected port: COM1
Selected port: COM1
To connect SM-N910A phone you have to perform the following steps:
13. Restart phone.
Selected port: COM1
Selected model: SM-N910A
13. Restart phone.
Selected port: COM1
Selected port: COM1
Selected port: COM1
Selected port: COM1
Selected port: COM1
Selected port: COM1
Operation was canceled
\Cert-SM-N915T-355024060231017.cert
Selected port: COM1
Selected port: COM1
To connect SM-N915G phone you have to perform the following steps:
13. Restart phone.
Selected port: COM1
Selected model: SM-N915G
Selected port: COM1
To connect SM-N915T phone you have to perform the following steps:
13. Restart phone.
Selected port: COM1
Selected model: SM-N915T
13. Restart phone.
Selected port: COM1
Phone IMEI: Unknown
Selected port: COM1
Selected port: COM401
Phone IMEI: Unknown
Phone IMEI: Unknown
To connect SC-06D phone you have to perform the following steps:
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "UART" radio button to "PDA" value.
8. Go to "Qualcomm USB Settings".
9. Select "DM+Modem+ADB".
10. Press Home button.
11. Go to dial window.
12. Enter "*#9090#" number.
13. Set "Diag config" to "UART" value.
14. Restart phone.
15. Press "Read Info" in software.
To connect SC-03E phone you have to perform the following steps:
2. Go to Menu->Settings->Developer options.
7. Set "UART" radio button to "MODEM" value.
9. Select "DM+MODEM+ADB".
13. Select "DM/UM over HSIC".
14. Restart phone.
13. Restart phone.
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM401
Mode: Normal
Phone model: SC-01G
Incorrect IMEI
SW version: MPSS.DI.3.0.c5-00272-M9625TAARANAZM-1
Found phone on COM10
Phone connected successfully
Checking Certificate file...
Certificate file successfully checked
Writing new phone IMEI...
Checking certificate compatibility...
Certificate is compatible
Writing Certificate...
Certificate has been written successfully
Please, restart the phone to apply changes
Old 04-05-2015, 08:36   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
10x You also for test and report.
Page generated in 0.23855 seconds with 8 queries
