samsung i8190 emergency calls only? Welcome to Octoplus/Octopus Box Samsung software version 1.7.8 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I8190 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "PDA" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Reading info, please wait... Detected phone model: GT-I8190 Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Phone is Rooted Reading data from phone... Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... Phone found. Unlocking phone. This can take some time. Please wait... Please insert card into phone, if phone is locked, then type 00000000 Phone is successfully unlocked ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM5 Phone connection failed Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Old IMEI: 352220-06-394954-7 New IMEI: 352220-06-394954-7 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Old IMEI: 352220-06-394954-7 New IMEI: 352220-06-394954-7 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Detected phone model: GT-I8190 Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Reading EFS, please wait... EFS read successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Selected file must be *.aefs Writing EFS was canceled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Selected file must be *.aefs Writing EFS was canceled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Reading info, please wait... Detected phone model: GT-I8190 Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) dear supporter aurjent help how to problm solved? |
Do the next: 1. Install the latest Software version (Software). 2. Take out SIM and SD cardsrom the phone. 3. Make Factory data reset and wipe cache partition. 4. Make Unlosk again. 5. Re-start the phone, insert SIM card and try to rearch and select network manually. |
thanks dear netwaok not solved? how to problem soved?please aurjent solution need? Welcome to Octoplus/Octopus Box Samsung software version 1.8.1 ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I8190 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "PDA" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... ADB server killed. Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Can't root Android version 4.1.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Can't root Android version 4.1.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8190 Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM5 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Can't root Android version 4.1.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Can't root Android version 4.1.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Can't root Android version 4.1.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: GT-I8190 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 12 00:23:25 KST 2012 PDA version: I8190DXALL3 CSC version: I8190OLBALL4 SW version: I8190DXALL3 Phone IMEI: 352220063949547 Phone SN: R21F20E02KE Android version: 4.1.2 (JZO54K) Unlocking phone... Cheking Root Phone is Rooted Reading data from phone... Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... Phone found. Unlocking phone. This can take some time. Please wait... Please insert card into phone, if phone is locked, then type 00000000 Phone is successfully unlocked |
Try to re-flash the phone, try to make Repair IMEI, maybe this will help. Currently no other solution. |
