07-02-2013, 10:52 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: uk
Member: 973412 Status: Offline Thanks Meter: 117 | samsung p1000 flash done ----------------------------------------------------------------------------------- To connect GT-S7562 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-P1000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. Selected firmware file: P1000DXJPE_P1000DXJPE_P1000OLBJPE.oct Please switch your phone to the download mode and connect it to a PC. To put GT-P1000 device into download mode you have to perform the following steps: 1. Power off device. 2. Press and hold "Volume - " + "Power" buttons. Found phone on Firmware write started. Writing IBL+PBL section... IBL+PBL section has been written successfully. Writing SBL section... SBL section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing FACTORYFS section... FACTORYFS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed |
The Following 2 Users Say Thank You to wasibutt For This Useful Post: |
