01-23-2015, 13:12 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: efs Age: 33
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | Sm-n7500q read cert error [Solved] Selected port: COM5 Selected model: SM-N7500Q Detected phone model: SM-N7500Q Firmware compiled date: Wed Nov 19 23:56:48 KST 2014 PDA version: N7500QXXUCNK2 CSC version: N7500QTURCNJ2 SW version: N7500QJVUCNJ1 Phone IMEI: 35221006519..... Phone SN: RF1F30NAXTP Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading Certificate... Executing exploit... Exploit has been executed successfully Unknown security Reading Certificate failed Last edited by Octopus box; 01-23-2015 at 14:59. |
01-23-2015, 13:22 | #2 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | WİTH LATEST SOFTWARE STİLL SAME...CANNOT WRITE OR READ CERT... Welcome to Octoplus/Octopus Box Samsung software version 1.8.1 ----------------------------------------------------------------------------------- To connect SM-N7500Q phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N7500Q Detected phone model: SM-N7500Q Firmware compiled date: Wed Nov 19 23:56:48 KST 2014 PDA version: N7500QXXUCNK2 CSC version: N7500QTURCNJ2 SW version: N7500QJVUCNJ1 Phone IMEI: 3522100651.... Phone SN: RF1F30NAXTP Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading Certificate... Executing exploit... Exploit has been executed successfully Unknown security Reading Certificate failed |
01-23-2015, 13:45 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Check your PM, we have sent You new Software version. Try with this Software and post here the result. |
01-23-2015, 14:57 | #4 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | PROBLEM SOLVED...THANK YOU Welcome to Octoplus/Octopus Box Samsung software version 1.8.2 ----------------------------------------------------------------------------------- To connect SM-N7500Q phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-N7500Q Detected phone model: SM-N7500Q Firmware compiled date: Wed Nov 19 23:56:48 KST 2014 PDA version: N7500QXXUCNK2 CSC version: N7500QTURCNJ2 SW version: N7500QJVUCNJ1 Phone IMEI: ............................. Phone SN: RF1F30NAXTP Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading Certificate... Executing exploit... Exploit has been executed successfully Phone will restart now. Please don't disconnect cable! Certificate read successfully |
