Samsung J200H/DS FRP Locked [Solved] Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! |
Flash J200HXXU0APB3_J200HOJV0APB2_THR from sammobile and try again. Good Luck |
Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to write Sboot of an older (by release date) firmware via "Write Firmware" operation, with enabled "Advanced Mode" option, then repeat "Reset FRP/Reactivation/EE" operation. |
To connect SM-J200H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200H To put SM-J200H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.3.0 software version solved thanx |
Samsung J2 SM-J200H FRP Removed With OCTOPLUS https://s20.postimg.org/4jvyrog19/J200_H_FRP.pnghow to capture screen |
