02-13-2015, 11:02 | #1 (permalink) |
Major Poster Join Date: May 2008
Member: 774029 Status: Offline Thanks Meter: 5 | sc-04f unlock error..pls help octopus team [Solved] Selected port: COM1 Selected model: SC-04F Reading info, please wait... Detected phone model: SC-04F Firmware compiled date: Mon Dec 15 14:44:32 KST 2014 PDA version: SC04FOMU1VNL5 CSC version: SC04FDCM1VNF9 SW version: SC04FOMU1VNL5 Phone IMEI: 351889060609998 Phone SN: R38F40SR19H Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-04F Detected phone model: SC-04F Firmware compiled date: Mon Dec 15 14:44:32 KST 2014 PDA version: SC04FOMU1VNL5 CSC version: SC04FDCM1VNF9 SW version: SC04FOMU1VNL5 Phone IMEI: 351889060609998 Phone SN: R38F40SR19H Android version: 4.4.2 (KOT49H) Reading info... Phone was not found on the selected port! [/QUOTE] Phone was not found on the selected port...when i try to wipe security i already root the phone and i already flash the cache and recovery the you give...pls help me Last edited by Octopus box; 02-13-2015 at 12:38. |
02-13-2015, 11:18 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To root the phone, try to use the latest versions of VRoot, Kingo Root, IRoot Softwares. Also try to use TowelRoot. Try to use IMEI Certificates for SM-G900F. Also, read here: http://forum.gsmhosting.com/vbb/f684.../#post10809256, http://forum.gsmhosting.com/vbb/f684.../#post10817509. Note: before to perfrom Wipe Security, write cache and recovery file: https://mega.co.nz/#!X8AwnCyI!8hq4CN...iNZyVy2JKB0KZM. |
02-13-2015, 11:23 | #3 (permalink) | |
Member: 774029 Status: Offline Thanks Meter: 5 | I already root the phone sir...and also i write tis file Quote:
02-13-2015, 11:26 | #4 (permalink) | |
Member: 774029 Status: Offline Thanks Meter: 5 | Quote:
02-13-2015, 11:47 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Configure the phone correctly: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" button at "Main" tab in the Software. When phone's info will be read out correctly and fully from the "Main" tab in the Software, make Wipe Security. |
02-13-2015, 11:56 | #6 (permalink) | |
any solution...pls | |
