02-18-2023, 22:05 | #1 (permalink) |
Junior Member Join Date: Feb 2023 Location: istANBUL Age: 30
Member: 3031952 Status: Offline Thanks Meter: 0 | Samsung note 10 plus n975f u8 imei repair Turn on USB debugging on the phone. Connect powered-on phone to PC using USB via ADB. Searching ADB devices... Press "OK" button on the device to allow USB debugging ADB connect fail. Sisteme bağlı bir aygıt çalışmıyor. Make sure that "USB Debug" option on the device is turned on Turn on USB debugging on the phone. Connect powered-on phone to PC using USB via ADB. Searching ADB devices... Press "OK" button on the device to allow USB debugging OK Reading info... Detected model: SM-N975F Fingerprint: samsung/d2sxx/d2s:12/SP1A.210812.016/N975FXXU8HVE5:user/release-keys Firmware compiled date: Mon May 9 19:43:58 KST 2022 PDA version: N975FXXU8HVE5 CSC version: N975FOXM8HVE5 SW version: N975FXXU8HVE3 Build number: QB22108772 Phone SN: RF8M81HJTYY Android version: 12 (SP1A.210812.016) Sales code: TUR Carrier Id: XME Country: TURKEY HW platform: exynos9825 HW Chip: universal9825 HW Modem: REV0.6 Security patch level: 2022-05-01 Warranty Void: 1 Codename: d2sxx SIM 1 status: ABSENT SIM 2 status: ABSENT Modem board: SHANNON5000 Work ID: 0000000001A8E57E Starting Repair Network (Nov.2020) Selected model: SM-N975F Turn on USB debugging on the phone. Connect powered-on phone to PC using USB via ADB. Searching ADB devices... Press "OK" button on the device to allow USB debugging OK Reading info... Detected model: SM-N975F Fingerprint: samsung/d2sxx/d2s:12/SP1A.210812.016/N975FXXU8HVE5:user/release-keys Firmware compiled date: Mon May 9 19:43:58 KST 2022 PDA version: N975FXXU8HVE5 CSC version: N975FOXM8HVE5 SW version: N975FXXU8HVE3 Build number: QB22108772 Phone SN: RF8M81HJTYY Android version: 12 (SP1A.210812.016) Sales code: TUR Carrier Id: XME Country: TURKEY HW platform: exynos9825 HW Chip: universal9825 HW Modem: REV0.6 Security patch level: 2022-05-01 Warranty Void: 1 Codename: d2sxx SIM 1 status: ABSENT SIM 2 status: ABSENT Modem board: SHANNON5000 Checking network status... Rebooting device... OK Searching ADB devices... OK This could be a special phone where root can be included in the recovery partition. This means that the phone must be started in recovery mode with a key combo or restarted in recovery mode via adb. If you are sure that your phone is rooted and want to restart in recovery mode, click "Yes" Rebooting device... OK Searching ADB devices... OK Connecting to server... Username: cantelekom1 Rebooting device... OK Do you want to start checking repair network status? It can take up to 10 minutes. Press "Yes" to start network status check, or "No" and check it manually by inserting sim card. Repair Network (Nov.2020) done Execution time 2 minute(s) 43 second(s) Performed by 4.0.9.2 Software version Last edited by Octopus box; 02-19-2023 at 13:01. |
