08-22-2015, 15:10 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | samsung s4 i9500 Not register on network Baseband , imei all things are ok. But when make dial it show not register on network. and when i downgrade the phone then Baseband is Unknown. please suggest me what should i do now....... |
08-24-2015, 07:49 | #3 (permalink) | |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Quote:
I9500XXUFNB3_I9500ODDFNB3_INU then phone baseband and imei is unknown PDA version: I9500XXUFNB3 CSC version: I9500ODDFNB3 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) and when i try to flash with this file Selected firmware file: i9500xxuhoc5_i9500ojvhoc2_xsg_android_5.0.1.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed everytime it fails on 75% then i flash the phone with I9500XXUHOC5_I9500OJVHOC2_I9500XXUHOA7_HOME.tar.md 5 this firmware and phone is ok now But Octopus show imei is inknown PDA version: I9500XXUHOC5 CSC version: I9500OJVHOC2 SW version: I9500XXUHOA7 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) and the phone imei show is 357138053233026 ( and this imei not match with the backpart) when i try to make call then show "Not register on Network" | |
08-24-2015, 11:25 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please install latest Software version, fully charge phone's battery, then try to do the next: 1. Make Repair EFS. 2. Re-flash the phone. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI). 4. Re-flash the phone again. 5. Re-start the phone, search and select network manually. 6. Post here full Software log with all of your actions and say the result. |
08-25-2015, 09:15 | #5 (permalink) | |
Code: Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Fri Mar 20 20:44:04 KST 2015 PDA version: I9500XXUHOC5 CSC version: I9500OJVHOC2 SW version: I9500XXUHOA7 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Reading security backup, please wait... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9500-Unknown25-08-2015_13-40-25-.asec file Cheking security type... New security type is detected Executing exploit... Write IMEI failed Code: Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Searching for a phone. Please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Thu Feb 13 20:33:19 KST 2014 PDA version: I9500XXUFNB3 CSC version: I9500ODDFNB3 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) | |
08-25-2015, 10:39 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Downgrade of phone's firmware is not recommended due to fact, that it can damage your device. Try upgrade phone's firmware version back to Android 5.0.1 to restore phone's modem part. |
08-25-2015, 14:02 | #7 (permalink) | |
i update the phone with this ver I9500XXUHOC5_I9500OJVHOC2_I9500XXUHOA7_HOME.oct and phone base band is OK. please suggest me what modem file is suitable for my phone | |
08-31-2015, 08:10 | #8 (permalink) |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | at last i downgrade the phone to 4.4.2 Baseband and Imei is ok. Now first i make repair Efs then flash then Repair imei and network But when i repair network after then Baseband is going to Unkonwn. any suggestion please |
08-31-2015, 11:00 | #10 (permalink) | |
Code: Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Searching for a phone. Please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Tue Oct 28 00:38:58 KST 2014 PDA version: I9500UBUGNJCSC version: I9500UUBGNJ1 SW version: I9500UBUGNJ1 Phone IMEI: 357512057407424 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Code: Selected port: COM1 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Selected firmware file: I9500UBUGNJ1_I9500UUBGNJ1_I9500UBUGNJ1_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. But its fail then i root the phone with Chimera Tool Code: Chimera Mobile Phone Utility version: 7.52.1122 @ 2015-08-31 [Rooting phone started] Rooting by generic root method 2... Rooting in progress. Be patient! Do NOT disconnect the phone! Root method failed. Checking custom root image... Checking image. Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking image. Present. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing recovery.img. Flashing cache.img. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Finished successfully. Finished at local time: [08.31.15 15:33:08] WorkID: 6726209 But after completing Job Phone Baseband Show Unkonwn. Then i flash the phone again and imei show 044... and Country Lock Code: Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Tue Oct 28 00:38:58 KST 2014 PDA version: I9500UBUGNJ1 CSC version: I9500UUBGNJ1 SW version: I9500UBUGNJ1 Phone IMEI: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9500-Unknown31-08-2015_15-34-17-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: 004999-01-064000-0 New IMEI: 352993-05-004470-0 Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM4 Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone connection failed Selected firmware file: I9500UBUGNJ1_I9500UUBGNJ1_I9500UBUGNJ1_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Tue Oct 28 00:38:58 KST 2014 PDA version: I9500UBUGNJ1 CSC version: I9500UUBGNJ1 SW version: I9500UBUGNJ1 Phone IMEI: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Code: Platform: Samsung Android Selected port: COM4 Selected model: GT-I9500 Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Tue Oct 28 00:38:58 KST 2014 PDA version: I9500UBUGNJ1 CSC version: I9500UUBGNJ1 SW version: I9500UBUGNJ1 Phone IMEI: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Phone unlocking failed | |
08-31-2015, 12:04 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, re-flash the phone with 5.0.1 Android version and try to "Unlock" the phone again, post here result. Last edited by Octopus box; 08-31-2015 at 13:10. |
08-31-2015, 13:19 | #12 (permalink) | |
Code: Selected firmware file: I9500XXUHOC5_I9500OJVHOC2_I9500XXUHOA7_HOME.oct Selected firmware file: I9500XXUHOC5_I9500OJVHOC2_I9500XXUHOA7_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Searching for a phone. Please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Phone found. Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Firmware compiled date: Fri Mar 20 20:44:04 KST 2015 PDA version: I9500XXUHOC5 CSC version: I9500OJVHOC2 SW version: I9500XXUHOA7 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9500 Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9500 Firmware compiled date: Fri Mar 20 20:44:04 KST 2015 PDA version: I9500XXUHOC5 CSC version: I9500OJVHOC2 SW version: I9500XXUHOA7 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Reading security backup, please wait... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Phone unlocking failed | |
09-15-2015, 14:37 | #14 (permalink) | |
and after unlock baseband is unknown and make flash then everything is Ok and it shows emergency calls only. i try to select network manually. and select network but on screen show : No Service Selected Network (Robi) not available. Suggest something please..... | |
