Samsung SC-03E (Docomo Galaxy S III) Easy to Unlock "READ CODE" only Samsung SC-03E (Docomo Galaxy S III) Unlock Done Procedure : I To connect SC-03E phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value 8. Go to "Qualcomm USB Settings" http://i1096.photobucket.com/albums/...ps96a5bfb6.jpg 9. Select "RNDIS+DM+MODEM". 10. Close window. 11. Go to dial window. 12. Press "Read Info" in software. Procedure : II 1. Enter "*#7284#" number. 2. Set "USB" radio button to "PDA" value. http://i1096.photobucket.com/albums/...ps9bc44952.jpg 3. select (check) "Manual select" option and try again with each COM port http://i1096.photobucket.com/albums/...psa2f64d6b.png READ CODE DONE http://i1096.photobucket.com/albums/...psd6b1758c.jpg DONE |
Welcome to Octopus Box Samsung software version 1.8.3 ----------------------------------------------------------------------------------- To connect SC-03E phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Close window. 11. Go to dial window. 12. Press "Read Info" in software. ------------------------------------------------------------- Platform: Samsung Android Selected port: COM148 Selected model: SC-03E Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SC-03E) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Nov 20 2012 Firmware compiled time: 00:00:00 Firmware released date: Feb 8 2013 Firmware released time: 08:46:08 Phone IMEI: 353986-05-024742-1 SW Version: M9615A-CEFWMAZM-2.0.146012 Unlocking phone... Phone is successfully unlocked Please, restart the phone to apply changes |
samsung sc-03 unlocking it is right way to read code for sc-03 by octopus To connect SC-03E phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+MODEM+ADB"and tab OK. 10.Next type *#9090# on phone 11.Salect DM/DUN over HSIC 12.wait for phone to resrart 13. select (check) "Manual select" option and try again with each COM port 12. Press "Read Info" in software. |
Samsung SC-03E cant unlock Samsung SC-03E (Docomo Galaxy S III) , when key in *#9090# or *#7284* nothing happen, how to unlock it ? I tried with uart or usb don't detect http://i643.photobucket.com/albums/u...ps80d25d31.jpg I needed help please BR |
Try to re-flash your phone and repeat the operation. |
I have re-flash ready but still the same, I have 2 phnones the same problem |
Currently we don't know another way how to connect your device. Try to search and write different firmwares and try again... |
No need to flash. Also check you IMEI, if you don't have IMEI then this is another motive to not work *#9090# |
Samsung SC-03E (Docomo Galaxy S III) how to repair Unknown baseband and also IMEI repair. *#9090# code not working, only blank screen. how to fix it. |
Most likely, phopne's EFS is damaged. Octopus/Octoplus Software currently doesn't support Repair EFS for this device. |
Many time try imei rep but its say phone emergency how to solve my phone is rooted any buddy help me |
1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Close window. 11. Go to dial window. 12. Press "Read Info" in software. |
change ypur keypad to samsung keypad |
i am all ready chk all cmd even i try all its same problem i need remortly help hoe can i do this 3 days itry but not done |
What is the IMEI in your device, what is the phone's baseband exactly? Try to re-flash the phone and then connect again. Post here full Software log. |
