02-18-2017, 15:26 | #1 (permalink) | |
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Need DRK Repair for SM-G920A 6.0.1 [Solved] need drk repair for G920A 6.0.1 after flash this firmware G920AUCS4CPG1 phone booting in recovery mode and showing this Quote:
can any body help me.... Last edited by Octopus box; 10-18-2017 at 07:48. | |
02-18-2017, 15:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. To fix corrupted DRK You need to do the next: 1. Root the phone. 2. Perform "DRK fix" operation. 3. Reflash the phone with an original firmware. |
02-19-2017, 00:26 | #3 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 46
Member: 152445 Status: Offline Thanks Meter: 16 | -flash this https://www.androidfilehost.com/?fid=529152257862699084 -repair drk via uart (octopus) -flash this https://www.androidfilehost.com/?fid=312968873555003924 -end |
The Following User Says Thank You to j_gerdts For This Useful Post: |
02-22-2017, 13:21 | #4 (permalink) | |||
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Quote:
thanks for reply brother... i tried your solution but no luck... when i try to repair drk via uart i get this error... Quote:
and when i try to repair drk via usb cable i get this error... Quote:
02-22-2017, 13:32 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Please download and install test Software version from "samsung/TEST SOFTWARE" folder of the Support Area. Repeat "DRK fix" operation via UART interface with test Software and post here the result. |
09-04-2017, 08:27 | #6 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PhnomPenh Cambodia
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | Platform: Samsung Android Selected port: COM137 Selected model: SM-G920A Note: Type *#0*# on the phone and connect UART cable. Searching for device. Please wait... Found phone on COM137 Reading info... Device model: SM-G920A Device IMEI: 00000000000000 MSL address: 0000000000 DM-Verity verification.. Fixing DRK.. DM-Verity verification..Ok! DRK fixed successfully Performed by 2.5.8 Software version. |
The Following 3 Users Say Thank You to kjava For This Useful Post: |
10-17-2017, 15:05 | #7 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2678967 Status: Offline Thanks Meter: 3 | I have the same problem. After unlocking I am getting unknown baseband and imei. I tried the dm verification then click repair efs . Rebooted the phone same thing unknown baseband and imei. Tried flashing the phone . Phone is stuck on recovery screen. in the bottom it is maked in red dm-verify verification failed ... need to check drk first. How do i get out from recovery clearing cache doesnt help I checked the octoplus folder i am seeing a backup of the phone .Will this help in any way. Last edited by C4savage; 10-17-2017 at 15:10. |
10-17-2017, 15:22 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. Please, try to refllash the phone with stock firmware. Also, please post here full Software log with all performed operations. |
10-17-2017, 21:55 | #9 (permalink) |
Member: 2678967 Status: Offline Thanks Meter: 3 | Flashed software but it is still stuck on android recovery . in the bottom in red device does not have drk contact sw pl please flash eng binary then install drk Welcome to Octoplus/Octopus Box Samsung software version 2.5.7 ----------------------------------------------------------------------------------- To connect SM-G920A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G920AUCS6DQC1_G920AATT6DQC1 _ATT_Android_6.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G920A into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.5.7 Software version. |
10-18-2017, 07:47 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Do the following: 1. Root the phone. 2. Perform "DRK fix" operation. 3. Post here full Software log. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
10-20-2017, 01:44 | #11 (permalink) |
Member: 2678967 Status: Offline Thanks Meter: 3 | Sucess at last Welcome to Octoplus/Octopus Box Samsung software version 2.5.7 ----------------------------------------------------------------------------------- To connect SM-G920T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-G920A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G920A Detected phone model: SM-G920A Firmware compiled date: Fri Mar 10 15:58:22 KST 2017 PDA version: G920AUCS6DQC1 CSC version: G920AATT6DQC1 SW version: G920AUCS6DQC1 Phone SN: RF1D45EJGGR Android version: 6.0.1 (MMB29K) Sales code: ATT Country: USA HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Security patch level: 2017-03-01 SIM 1 status: absent Codename: zeroflteuc Checking Root: Phone is Rooted. Initializing exploit... Executing exploit... DM-Verity verification..not good! Fixing DRK.. DRK fixed successfully Performed by 2.5.7 Software version. |
The Following User Says Thank You to C4savage For This Useful Post: |
