10-20-2015, 09:00 | #1 (permalink) |
Insane Poster Join Date: Sep 2011 Location: mardan
Member: 1650402 Status: Offline Sonork: 100.1623178 Thanks Meter: 14 | sm-g920f flashing error please help octopus team..... |
10-20-2015, 09:26 | #2 (permalink) |
Member: 1650402 Status: Offline Sonork: 100.1623178 Thanks Meter: 14 | logs for SM-G920F Welcome to Octoplus/Octopus Box Samsung software version 2.0.8 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: G920FXXU2POFC_G920FVFG2BOF2 _SWC_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G920F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... Writing Firmware Failed |
10-20-2015, 09:49 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to write different firmwares. Try to reflash the phone with original firmware and flashing tool. No other solution. |
10-20-2015, 09:58 | #4 (permalink) |
Freak Poster Join Date: Oct 2012 Location: United Arab Emirates
Member: 1829029 Status: Offline Thanks Meter: 20 | G920F flashing failed G920F flashing failed solution!! first delet .md5 from name of firmware then open firmware with winrar and delet hidden file from firmware. after try fo flash... |
10-20-2015, 10:01 | #6 (permalink) |
Member: 1829029 Status: Offline Thanks Meter: 20 | G920F flashing failed solution!! first delet .md5 from name of firmware then open firmware with winrar and delet hidden file from firmware. after try fo flash... |
10-20-2015, 10:20 | #8 (permalink) | ||
Member: 1829029 Status: Offline Thanks Meter: 20 | Quote:
first delet .md5 from name of firmware then open firmware with winrar and delet hidden file from firmware. after try fo flash... Quote:
