Samsung SM-G900A S5 Unlock Done Samsung SM-G900A S5 Unlock Done 1.Root The Phone Using The File http://s29.postimg.org/t1nsnlwp3/root.jpg 2.Open Octopus &Repair Security/Wipe Security http://s4.postimg.org/ikbzmt5rx/Capture.jpg 3.Download Certificate From Support&Write Certificate http://s9.postimg.org/crtth84zj/Capture2.jpg Unlock Log: Quote:
DON'T SAY THANKShttp://s21.postimg.org/cg8qb6flv/hand.gif JUST PRESS BUTTONhttp://s21.postimg.org/s0g41ppqb/animatedthanks.gif http://s2.postimg.org/oh0jea9yt/4115602.gif by: Habeeb Kambrath |
Thanks for your good and detailed report. :) |
You're forgetting a step. This guide leaves you on an unstable kernel. |
S5 SM-G900A Android 4.4.4 Rooting Steps:- 1.Download&Install Towelroot V3.apk 2.Handset Put Into Download Mode And Flash The File(Put This File In PDA) 3.Open the Towelroot app and Press "Make it Rain" to root your device. 4.Power Off Your Mobile& Boot In to Download Mode Again Flash The File 5.Install Super Su to Manage Root Access. Done! |
Now the guide is complete :) |
and do with otcopus box |
Thanks |
I think you try with odin,working this files fine...please change your version of odin |
I did all the steps but its asking me for sm-g900a cert file ? dunno where that is ? |
All Certificates files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/Certificates/". For SM-G900A You can use IMEI Certificates from SM-G900F. |
can you share the root file you've use? root file given is not valid |
not valid means????????? |
The above(files in my post)files work fine |
I need only the firmware 4.4.4 I need only the firmware 4.4.4 for the SM-G900A, and I can't find it. I don't want to root the phone. Can you tell me where can I find only the firmware 4.4.4 so that I flash it to my S5? Thank you |
Unfortunately we don't have Android 4.4.4 firmware for SM-G900A. We will try to find 4.4.4 firmware. If we will find it, firmware will be available in the Support Area. |
