04-06-2016, 11:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: International
Member: 1728527 Status: Offline Sonork: 100.1668555 Thanks Meter: 67 | Samsung SM-N9200 FRP Unlock Failed [Solved] Selected port: COM1 Selected model: SM-N9200 To put SM-N9200 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Reset operation completed! Performed by 2.2.3 software version Flashed SBOOT.BIN & MODEM.BIN After Tried Unlock Again - Unlock Success in Software Still Locked in Phone Last edited by Octopus box; 08-08-2016 at 10:07. |
04-06-2016, 11:59 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,425 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to reflash the phone with older (by release date) firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
08-07-2016, 16:24 | #3 (permalink) |
Freak Poster Join Date: May 2016 Location: Saudi Arab Dammam
Member: 2574123 Status: Offline Sonork: 100.1652460 Thanks Meter: 11 | i GOT SECCUSS IN NEW UPDATE OF OCTOPUS Welcome to Octoplus/Octopus Box Samsung software version 2.3.2 ----------------------------------------------------------------------------------- To connect SM-J500F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N9200 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM121 Selected model: SM-N9200 To put SM-N9200 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Operation was canceled Performed by 2.3.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM121 Selected model: SM-N9200 Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Rebooting phone failed. Performed by 2.3.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM121 Selected model: SM-N9200 Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Rebooting phone failed. Performed by 2.3.2 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM121 Selected model: SM-N9200 To put SM-N9200 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Reset operation completed! Performed by 2.3.2 software version DONE.............. THANKS OCTOPUS TEAM |
