Samsung SM-J500F no service problem [Answered] Welcome to Octoplus Box Samsung software version 2.6.6 ----------------------------------------------------------------------------------- To connect SM-J200H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J500F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J500F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM9 Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.6.6 Software version. |
Hello. After of which operations device get this problem ("no service problem")? At first please check IMEI Certi status (*#0011#) and write it here. |
dear my device problem no service but usb setting not working not informaitnf |
Platform: Samsung Android Selected port: COM12 Selected model: SM-J500F Operation: Write QCN Reading info... Phone was not found on the selected port! Writing QCN failed Performed by 2.6.6 Software version. |
Please, make sure that You set up your device, before perform any operation with your device: To connect SM-J500F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. |
Please, try to perform Enable DIAG operation, then try to repeat Raed phone info operation. Also, please open Device manager, make screenshot and post here. |
Welcome to Octoplus Box Samsung software version 2.6.6 ----------------------------------------------------------------------------------- To connect SM-J500F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Mode: Normal Phone model: SM-J500F Firmware compiled date: May 24 2016 Firmware compiled time: 05:00:00 Firmware released date: Jun 29 2016 Firmware released time: 15:58:42 Phone IMEI: 352141-07-033667-8 SW version: MPSS.DPM.2.0.2.c1.7-00040-M8936FAAAANUZM-1.57454.1 Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Mode: Normal Phone model: SM-J500F Firmware compiled date: May 24 2016 Firmware compiled time: 05:00:00 Firmware released date: Jun 29 2016 Firmware released time: 15:58:42 Phone IMEI: 352141-07-033667-8 SW version: MPSS.DPM.2.0.2.c1.7-00040-M8936FAAAANUZM-1.57454.1 Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM9 Mode: Normal Phone model: SM-J500F Firmware compiled date: May 24 2016 Firmware compiled time: 05:00:00 Firmware released date: Jun 29 2016 Firmware released time: 15:58:42 Phone IMEI: 352141-07-033667-8 SW version: MPSS.DPM.2.0.2.c1.7-00040-M8936FAAAANUZM-1.57454.1 Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Operation: Write QCN Reading info... Phone was not found on the selected port! Writing QCN failed Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Operation: Read info Reading info, please wait... Detected phone model: SM-J500F Firmware compiled date: Mon Jul 31 15:27:25 KST 2017 PDA version: J500FXXU1BQG9 CSC version: J500FOJV1BQG2 SW version: J500FXXU1BPF3 Phone SN: RV8H6234N8F Android version: 6.0.1 (MMB29M) Sales code: XSG Country: UAE HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Security patch level: 2017-08-01 SIM 1 status: not ready SIM 2 status: not ready Codename: j5ltexx Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Operation: Write QCN Reading info... Phone was not found on the selected port! Writing QCN failed Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Mode: Normal Phone model: SM-J500F Firmware compiled date: May 24 2016 Firmware compiled time: 05:00:00 Firmware released date: Jun 29 2016 Firmware released time: 15:58:42 Phone IMEI: 352141-07-033667-8 SW version: MPSS.DPM.2.0.2.c1.7-00040-M8936FAAAANUZM-1.57454.1 Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Mode: Normal Phone model: SM-J500F Firmware compiled date: May 24 2016 Firmware compiled time: 05:00:00 Firmware released date: Jun 29 2016 Firmware released time: 15:58:42 Phone IMEI: 352141-07-033667-8 SW version: MPSS.DPM.2.0.2.c1.7-00040-M8936FAAAANUZM-1.57454.1 Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Operation: Write QCN Reading info... Phone was not found on the selected port! Writing QCN failed Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Operation: Write Cert Selected file: D:\SAMSUNG\ALL FLASH FILE\J500F\j500f Full Repair\j500f Full Repair\j500F Dual imei\j500F Dual imei\CERT\SM-J500F_352141070336678_35214107033667\SM-J500F_352141070336678_35214107033667.cert Select Certificate2... Selected file: D:\SAMSUNG\ALL FLASH FILE\J500F\j500f Full Repair\j500f Full Repair\j500F Dual imei\j500F Dual imei\CERT\SM-J500F_352141070336678_35214107033667\SM-J500F_352141070336678_35214107033667.cert Detected phone model: SM-J500F Firmware compiled date: Mon Jul 31 15:27:25 KST 2017 PDA version: J500FXXU1BQG9 CSC version: J500FOJV1BQG2 SW version: J500FXXU1BPF3 Phone SN: RV8H6234N8F Android version: 6.0.1 (MMB29M) Sales code: XSG Country: UAE HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Security patch level: 2017-08-01 SIM 1 status: absent SIM 2 status: absent Codename: j5ltexx Checking Root: Phone is not Rooted. Writing Certificate failed Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM9 Port is busy Connecting to phone on COM10 Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Mode: Normal Phone model: SM-J500F Firmware compiled date: May 24 2016 Firmware compiled time: 05:00:00 Firmware released date: Jun 29 2016 Firmware released time: 15:58:42 Phone IMEI: 352141-07-033667-8 SW version: MPSS.DPM.2.0.2.c1.7-00040-M8936FAAAANUZM-1.57454.1 Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Operation: Write QCN Reading info... Phone was not found on the selected port! Writing QCN failed Performed by 2.6.6 Software version. |
As i can see from the Software log: Phone is not Rooted. Please, try to root the device manually, after please repeat Write Cert operation. Post here full Software log. |
Platform: Samsung Android Selected port: COM9 Selected model: SM-J500F Operation: Write Cert Selected file: D:\SAMSUNG\ALL FLASH FILE\J500F\j500f Full Repair\j500f Full Repair\j500F Dual imei\j500F Dual imei\CERT\SM-J500F_352141070336678_35214107033667\SM-J500F_352141070336678_35214107033667.cert Select Certificate2... Selected file: D:\SAMSUNG\ALL FLASH FILE\J500F\j500f Full Repair\j500f Full Repair\j500F Dual imei\j500F Dual imei\CERT\SM-J500F_352141070336678_35214107033667\SM-J500F_352141070336678_35214107033667.cert Detected phone model: SM-J500F Firmware compiled date: Mon Jul 31 15:27:25 KST 2017 PDA version: J500FXXU1BQG9 CSC version: J500FOJV1BQG2 SW version: J500FXXU1BPF3 Phone SN: RV8H6234N8F Android version: 6.0.1 (MMB29M) Sales code: XSG Country: UAE HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Security patch level: 2017-08-01 SIM 1 status: not ready SIM 2 status: not ready Codename: j5ltexx Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed Performed by 2.6.6 Software version. |
Information about new Qualcomm firmwares: In the latest firmware versions of Qualcomm-based phones ability to Unlock and Reset MSL was disabled. If you cannot Unlock or Reset MSL on a Qualcomm phone, you need to check phone's firmware release date. If firmware was released after 01.10.2015, then you can try to downgrade phone's firmware (write older, by release date, version of firmware). |
Welcome to Octoplus Box Samsung software version 2.6.6 ----------------------------------------------------------------------------------- To connect SM-J500F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Selected firmware file: J500FXXU1AOG1_J500FOJV1AOG3_XSG_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J500F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing QSEE section... QSEE section has been written successfully. Writing QHEE section... QHEE section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing sec section... sec section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. Performed by 2.6.6 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J500F Operation: Reset MSL Reading info... Phone was not found on the selected port! Operation was failed! |
As I have written above, "Reset MSL" works only with firmwares, which release date is up to 01.10.2015. Write firmware with release date to 01.10.2015 and only then perform "Reset MSL" operation. |
Try Writing QCN Hello Honor Able! you've downloaded CERT from sport Area also download QCN File from net or Working phone... or download it from HERE |
