07-16-2015, 07:50 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | i9500 imei null after downgrade, please how will I solve it! I wanted to change this I9500 version 5.0.1 imei but it didn't work so I downgrade it and change the imei but it didn't work and now even if I update it it might have imei back but saying "not registered on network", please anyway to get the phone back working even if I do not change the imei again? Logs below; Downgrading logs; Selected firmware file: I9500UBUGNI1_I9500ZTOGNI1_I9500UBUGNI1_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. writing super imei logs; Platform: Samsung Android Selected port: COM16 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Tue Sep 9 20:17:09 KST 2014 PDA version: I9500UBUGNI1 CSC version: I9500ZTOGNI1 SW version: I9500UBUGNI1 Phone IMEI: 004999010640000 Phone SN: RF1D711VTLY Android version: 4.4.2 (KOT49H) Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9500-Unknown16-07-2015_07-32-01-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: 004999-01-064000-0 New IMEI: 352993-05-004445-2 Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Please help me out because customer is on my neck. |
07-16-2015, 09:04 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. Try to do exactly the next: 1. Make Repair EFS. 2. Re-flash the phone. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI). 4. Re-flash the phone again. 5. Re-start the phone, search and select network manually. 6. Post here full Software log with all of your actions and say the result. |
07-16-2015, 11:45 | #5 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
I have done every thing as you said but it has not worked yet but now imei is 00499901064000/02 after your steps, below are the logs; 1. Make Repair EFS log; Platform: Samsung Android Selected port: COM3 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully 2. Re-flash the phone log; Selected firmware file: I9500ZSUHOC2_I9500OZSHOC2_I9500ZSUHOC2_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Firmware writing successfully completed. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI) log; Platform: Samsung Android Selected port: COM16 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Fri Mar 13 16:18:03 KST 2015 PDA version: I9500ZSUHOC2 CSC version: I9500OZSHOC2 SW version: I9500ZSUHOC2 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9500-Unknown16-07-2015_09-56-26-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: Unknown New IMEI: 352993-05-004451-0 Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) 4. Re-flash the phone again log; Selected firmware file: I9500ZSUHOC2_I9500OZSHOC2 _I9500ZSUHOC2_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Firmware writing successfully completed. info read log after all; ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: GT-I9500 Port is busy Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Mar 13 16:18:03 KST 2015 PDA version: I9500ZSUHOC2 CSC version: I9500OZSHOC2 SW version: I9500ZSUHOC2 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Please any other help, the owner is on my neck? | |
07-16-2015, 12:07 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Please make Factory Reset and repeat "Repair IMEI" operation (write service IMEI from the Software list, not any IMEI). Note: it is important to restart the phone via its menu as operation ends (don't disconnect the battery!). Also look here: http://forum.gsmhosting.com/vbb/f684...olved-1952431/ |
07-16-2015, 12:48 | #7 (permalink) | |
I tried that but it didnt work and I try to write the three cert you share at the other link but didnt work, please any way out? The problem is that whenever I repired imei or network, it get to null/null. Below is my cert writing error logs; Platform: Samsung Android Selected port: COM20 Selected model: GT-I9500 Selected file: C:\Users\LIONFINGER\Desktop\test\New folder\cert\Cert-GT-I9500_351245874585850_R21DC20VJ8.cert Detected phone model: GT-I9500 Firmware compiled date: Fri Mar 13 16:18:03 KST 2015 PDA version: I9500ZSUHOC2 CSC version: I9500OZSHOC2 SW version: I9500ZSUHOC2 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: GT-I9500 Selected file: C:\Users\LIONFINGER\Desktop\test\New folder\cert\Cert-GT-I9500_351612060479703_R31DB24TEE.cert Detected phone model: GT-I9500 Firmware compiled date: Fri Mar 13 16:18:03 KST 2015 PDA version: I9500ZSUHOC2 CSC version: I9500OZSHOC2 SW version: I9500ZSUHOC2 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is not compatible Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: GT-I9500 Selected file: C:\Users\LIONFINGER\Desktop\test\New folder\cert\Cert-GT-I9500_357138052400196_RF1D46DB4A.cert Detected phone model: GT-I9500 Firmware compiled date: Fri Mar 13 16:18:03 KST 2015 PDA version: I9500ZSUHOC2 CSC version: I9500OZSHOC2 SW version: I9500ZSUHOC2 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Checking Root: Phone is Rooted. Checking Certificate file... Checking Certificate failed Writing Certificate failed | |
The Following User Says Thank You to lionfinger2007 For This Useful Post: |
07-16-2015, 13:11 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Please reflash the phone, then try to write "Cert-GT-I9500_351612060479703_R31DB24TEE.cert" Cert file again. Post here results and full Software logs of performed operations. |
07-16-2015, 14:47 | #9 (permalink) | |
I did as you told me and the process went fine but the imei is still 004999010640000/02. What else will I do? Below are the logs; Flashing log; Welcome to Octoplus/Octopus Box Samsung software version 2.0.1 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: I9500ZSUHOC2_I9500OZSHOC2_I9500ZSUHOC2_HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Firmware writing successfully completed. ----------------------------------------- Cert writing log; Platform: Samsung Android Selected port: COM16 Selected model: GT-I9500 Selected file: C:\Users\LIONFINGER\Desktop\test\New folder\cert\Cert-GT-I9500_351612060479703_R31DB24TEE.cert Detected phone model: GT-I9500 Firmware compiled date: Fri Mar 13 16:18:03 KST 2015 PDA version: I9500ZSUHOC2 CSC version: I9500OZSHOC2 SW version: I9500ZSUHOC2 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Checking for compatible Certificate and phone... Certificate is compatible Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes Thanks for your time sir, please still help me out. | |
07-16-2015, 16:34 | #10 (permalink) |
Member: 576282 Status: Offline Thanks Meter: 145 | After this last step, it get the phone lock and where asking for a network unlock code and I have unlocked it now but the imei is still what it is, please any cert to get this phone working? Unlocking logs; Welcome to Octoplus/Octopus Box Samsung software version 2.0.1 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Fri Mar 13 16:18:03 KST 2015 PDA version: I9500ZSUHOC2 CSC version: I9500OZSHOC2 SW version: I9500ZSUHOC2 Phone IMEI: Unknown Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9500-Unknown16-07-2015_16-30-05-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Unlocking phone. This can take some time. Please wait... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
07-16-2015, 17:59 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Try to do exactly the next: 1. Make Repair EFS. 2. Re-flash the phone with "i9500xxuhoc5_i9500ojvhoc2_xsg_android_5.0.1" firmware from the Support Area. 3. Write "Cert-GT-I9500_351612060479703_R31DB24TEE.cert" Cert file. 4. Re-flash the phone with "i9500xxuhoc5_i9500ojvhoc2_xsg_android_5.0.1" firmware again. 5. Check phone's IMEI. 6. Post here full Software log with all of your actions and say the result. |
07-17-2015, 15:46 | #12 (permalink) | |
I did that, it can reset efs but for flashing, it keep on stopping along the way! Below is the logs; EFS RESET! Platform: Samsung Android Selected port: COM3 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Flashing logs; Selected firmware file: i9500xxuhoc5_i9500ojvhoc2_xsg_android_5.0.1.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed Still need help and please sir! If I download lower version like 4.3, will this problem be over? | |
07-17-2015, 16:01 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Please fully charge phone's battery and try to perform steps 1-5 with different firmwares. If problem will remain the same - this can be HW problem (problem with phone's flash chip). |
07-18-2015, 14:40 | #14 (permalink) | |
Hello sir, thanks so far! But the problem is not from battery neither is hardware, The phone was working fine before I downgrade it just to be able to change the imei and now is always saying "not registered on network" and the imei could not be repaired back. To show that is not battery I flashed it with odin and md5 file and it can flash complete but with the file you told me to use, it stops on the way. Please can you give me the md5 file link of the version you told me to use (expectially if is on sammobile site). Let me try it too, may be with the file it would be ok but something is preventing it from completing flashing with the great octolus. I love this box and I always stand for it 100%. Below is my flashing logs for odin and octoplus showing it not battery folt. Octoplus flashing log; Welcome to Octoplus/Octopus Box Samsung software version 2.0.1 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: i9500xxuhoc5_i9500ojvhoc2_xsg_android_5.0.1.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed Odin; <ID:0/016> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> I9500ZSUHOC2_I9500OZSHOC2_I9500ZSUHOC2_HOME.tar.md 5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/016> Odin engine v(ID:3.1005).. <ID:0/016> File analysis.. <ID:0/016> SetupConnection.. <ID:0/016> Initialzation.. <ID:0/016> Get PIT for mapping.. <ID:0/016> Firmware update start.. <ID:0/016> SingleDownload. <ID:0/016> sboot.bin <ID:0/016> NAND Write Start!! <ID:0/016> boot.img <ID:0/016> recovery.img <ID:0/016> system.img <ID:0/016> cache.img <ID:0/016> hidden.img <ID:0/016> modem.bin <ID:0/016> RQT_CLOSE !! <ID:0/016> RES OK !! <ID:0/016> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/016> Removed!! Please give me the md5 file version of the file you told me to use. Will like it to be from sammobile. | |
07-18-2015, 14:48 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | You can download original "i9500xxuhoc5_i9500ojvhoc2_xsg" firmware by this link. Also, please upload *.log and *.logx files of attempt to write the firmware. Post here download link we will check where might be the problem. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
