06-27-2020, 11:33 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Pakistan Age: 44
Member: 240756 Status: Offline Thanks Meter: 90 | Samsung Tab 4 SM-T535 flashing Failed [Answered] It was working fine problem was just sim Data not working reset Network but not fixed so then i flashed and now soft bricked..... Welcome to Octoplus Box Samsung software version 2.9.4.7 Card S/N : 00003E6E ----------------------------------------------------------------------------------- To connect SM-T535 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Selected BOOT file: H:\Samsung Firmware\T-Series \BL_T535XXU1BOD8_CL4741109_QB4756743_REV00 _user_low_ship_MULTI_CERT.tar.md5 Selected AP file: H:\Samsung Firmware\T-Series\AP_T535XXU1BOD8 _CL4741109_QB4756743_REV00 _user_low_ship_MULTI_CERT.tar.md5 Selected CP file: H:\Samsung Firmware\T-Series\CP_T535XXU1BOD8 _CL4741109_QB4756743_REV00 _user_low_ship_MULTI_CERT.tar.md5 Selected CSC file: H:\Samsung Firmware\T-Series \CSC_VFG_T535VFG1BOE3_CL4989622_QB5077000_REV00 _user_low_ship_MULTI_CERT.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-T535 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing Firmware Failed Performed by 2.9.4.7 Software version. |
The Following User Says Thank You to Aazib jhon For This Useful Post: |
06-27-2020, 12:15 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Please download and install latest test software version 2.9.5.2 from the Support Area (Samsung/TEST SOFTWARE/), put the phone into download mode then repeat the operation once again. Quote:
The Following 2 Users Say Thank You to Octopus support For This Useful Post: |
06-27-2020, 21:08 | #3 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 90 | Welcome to Octoplus Box Samsung software version 2.9.5.2 Card S/N : 00003E6E ----------------------------------------------------------------------------------- To connect SM-T535 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Selected BOOT file: H:\Samsung Firmware\T-Series \BL_T535XXU1BOD8_CL4741109_QB4756743_REV00 _user_low_ship_MULTI_CERT.tar.md5 Selected AP file: H:\Samsung Firmware\T-Series\AP_T535XXU1BOD8 _CL4741109_QB4756743_REV00 _user_low_ship_MULTI_CERT.tar.md5 Selected CP file: H:\Samsung Firmware\T-Series\CP_T535XXU1BOD8 _CL4741109_QB4756743_REV00 _user_low_ship_MULTI_CERT.tar.md5 Selected CSC file: H:\Samsung Firmware\T-Series \CSC_VFG_T535VFG1BOE3_CL4989622_QB5077000_REV00 _user_low_ship_MULTI_CERT.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-T535 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed Performed by 2.9.5.2 Software version. |
06-28-2020, 09:27 | #4 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 90 | Re T535 Tab 4 i tried to flash TWRP Recovery and installed successfully but can not mount system and failed.see image please. after that i tried to full flash but flashing failed. |
06-29-2020, 10:53 | #5 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 90 | INFO : 27-Jun-20 10:05:55 PM > Selected BOOT file: H:\Samsung Firmware\T-Series\BL_T535XXU1BOD8_CL4741109_QB4756743_REV00_u ser_low_ship_MULTI_CERT.tar.md5 INFO : 27-Jun-20 10:05:55 PM > Selected AP file: H:\Samsung Firmware\T-Series\AP_T535XXU1BOD8_CL4741109_QB4756743_REV00_u ser_low_ship_MULTI_CERT.tar.md5 INFO : 27-Jun-20 10:05:55 PM > Selected CP file: H:\Samsung Firmware\T-Series\CP_T535XXU1BOD8_CL4741109_QB4756743_REV00_u ser_low_ship_MULTI_CERT.tar.md5 INFO : 27-Jun-20 10:05:55 PM > Selected CSC file: H:\Samsung Firmware\T-Series\CSC_VFG_T535VFG1BOE3_CL4989622_QB5077000_RE V00_user_low_ship_MULTI_CERT.tar.md5 WARN : 27-Jun-20 10:05:57 PM > Please put the phone into Download Mode and connect USB cable. WARN : 27-Jun-20 10:05:57 PM > To put SM-T535 into Download Mode, You have to perform the following steps: WARN : 27-Jun-20 10:05:57 PM > 1. Reconnect the battery. WARN : 27-Jun-20 10:05:57 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed Performed by 2.9.5.2 Software version. Selected AP file: H:\Samsung Firmware\T-Series\AP_T535XXU1BOD8_CL4741109_QB4756743_REV00_u ser_low_ship_MULTI_CERT.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-T535 into Download Mode, You have to perform the following steps: Reconnect the battery. Press and hold "Volume-" + "Home" + "Power ON" keys. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed Performed by 2.9.5.2 Software version. Selected AP file: H:\Samsung Firmware\T-Series\AP_T535XXU1BOD8_CL4741109_QB4756743_REV00_u ser_low_ship_MULTI_CERT.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-T535 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... ERROR : 27-Jun-20 10:26:36 PM > Writing Firmware Failed INFO : 27-Jun-20 10:26:36 PM > Performed by 2.9.5.2 Software version. ERROR : 28-Jun-20 9:07:13 AM > MyExceptionEAccessViolationAccess violation at address 00C1CF98 in module 'OctoplusSamsung.exe'. Read of address 00000004 ERROR : 28-Jun-20 9:07:13 AM > TForm1 |
07-01-2020, 18:41 | #6 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 90 | Pleas Anyone Can Help me For this problem that why Flashing failed everytime at 30% 40% when flashing system Image file.bettry 80% charged change Firmware File.even download carrier file ************** which was installed before in device.what it problem could be.anyone can help me please..... |
