Says searching for phone, need help doing a note 3 after i connect to the usb uart cable it just says searching for phone, ill pay anyone for some help |
Hello. In order to connect the phone via UART, You need to block highlighted pin with a tape/paper and use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. http://i.imgur.com/wfV60I2l.jpg Also, try to reinstall FTDI drivers: http://octoplusbox.com/files/drivers...rs_2.08.24.zip |
can you show me what the cable looks like? i am trying to upload a pic and wont let me |
You can check correct pinout of the cable in phone's manual (press "Cable & Manual" button in Software). |
ok i got the phone to take the new imei which is off another tmobile note 3 that is not blacklisted however it shows the new imei everything looks correct but now says not registered on network it shows bars but will not make a call, also why does my box not let me chose from the Service imei??? im using version 1.65 |
Hi, allways use letest ver do next--- 1. Root your mobile 2. Wipe security 3.write cert if no network problem again 4.write qcn |
