03-22-2014, 10:14 | #1 (permalink) |
Major Poster Join Date: Dec 2013
Member: 2087773 Status: Offline Thanks Meter: 11 | help unlock sc01d [Solved] ----------------------------------------------------------------------------------- To connect SC-01D phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to Calculator application. 6. Enter "(+32286798378+" or "(+30012012732+" number, to get phone dial window. 7. Enter "*#1575#" number. 8. On phone keybord press "Menu" button, and select "Back". 9. Set "Diag config" to "USB" value. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "USB" radio button to "Modem" value. 13. Close window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SC-01D Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM24 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM28 Selected model: SC-01D Mode: Normal Phone model: SC-01D Firmware compiled date: Nov 09 2011 Firmware compiled time: 09:00:00 Firmware released date: Jan 3 2012 Firmware released time: 11:05:49 Incorrect IMEI Phone was not found on the selected port! ----------------------------------------------------------------------------------- Last edited by Octopus box; 03-23-2014 at 08:41. |
03-22-2014, 10:21 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. You have connected the device to not proper COM port, that's why Software can't read IMEI. Do the next: select correct COM port (try to select COM27 or COM29), select (check) "Manual select" option in Software and press "Read info" button. |
03-22-2014, 13:11 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You have connected the device to not proper COM port, select correct COM port, select "Manual select" option in Software and press "Read info" button. |
03-22-2014, 14:12 | #5 (permalink) | |
Member: 2087773 Status: Offline Thanks Meter: 11 | Quote:
I've done what you say, .. but teteap still like it Go to Calculator application. Enter "(+32286798378+".......nothing happens Enter "(+30012012732+" number, to get phone dial window. Enter "*#1575#" number.........nothing happens and than i try Enter "*#7284#" number. Set "USB" radio button to "Modem" value. Close window. select correct COM port, select "Manual select" option in Software and press "Read info" button Press "Read Info" in software. the result is always Platform: Samsung Android Selected port: COM17 Selected model: SC-01D Mode: Normal Phone model: SC-01D Firmware compiled date: Nov 09 2011 Firmware compiled time: 09:00:00 Firmware released date: Jan 3 2012 Firmware released time: 11:05:49 Incorrect IMEI Phone was not found on the selected port! | |
03-22-2014, 14:14 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to select COM16 and COM18, select (check) "Manual select" option in Software. |
03-23-2014, 07:58 | #7 (permalink) |
Member: 2087773 Status: Offline Thanks Meter: 11 | the problem in this Enter "*#1575#" number.........nothing happens... should Enter "*#9090#" number Set "Diag config" to "USB" value. Reboot device than Enter "*#7284#" number. Set "USB" radio button to "Modem" value. and sukses unlocked |
The Following User Says Thank You to iwagi For This Useful Post: |
