SHW-M210S can be flashed with firmware GT-S8530? SHW-M210S can be flashed with firmware GT-S8530?..... |
Hello. We have not tried to do this. But if You want to do this - please try and post the result here. |
Korean phone have different hardware with international version...m example : Korean Galaxy Gio SHW-M290K flsahed with International Galaxy Gio S5660, result : Phone works except wifi,radio & gps not working. |
B.R. Karel |
shw-m210s i tried one set first changed the boot then flashed and now first stage hang now trying its own file not writing |
To connect GT-S8530 phone you have to perform the following steps: 1. Go to dial window. 2. Enter "*#197328640#" number. 3. Make next steps: select Common->Service configuration->Data service confing->USB ACM AP. 4. Restart phone. 5. Press "Read Info" in Octopus Samsung software. Selected firmware file: S8530DXKB1_OLBKB1.oct Please put your phone in download mode and connect to PC. To put GT-S8530 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume+" +"Camera"+"Power" buttons. Searching for phone. Please wait... Found phone on COM57 Firmware write started. Writing BOOT\BOOT_LOADER section... Writing BOOT\DBL section... Phone will restart now. Please don't disconnect cable! Writing AMSS section... AMSS section has been written successfully. Writing APPS section... Writing Firmware Failed Please put your phone in download mode and connect to PC. To put GT-S8530 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume+" +"Camera"+"Power" buttons. Searching for phone. Please wait... Found phone on COM57 Firmware write started. Writing BOOT\BOOT_LOADER section... Writing BOOT\DBL section... Phone will restart now. Please don't disconnect cable! Writing AMSS section... AMSS section has been written successfully. Writing APPS section... Writing Firmware Failed Access violation at address 00000000. Read of address 00000000 |
Why have you tried to flash S8530 firmware? I wrote it is not possible. Do you have original repair flash M210s with bootloader? Which version was inside before flash? |
:D:D stuck at the logo, .. I flash with _M210SKRLC1_M210SSKTLC1_SKT (include boot), M210SKRLC2_M210SSKTLC2_SKT, and SHW-M210S_SKT_1 always fail, .. I tried all else failed |
Try flash again frimware S8530 with MultiLoader_V5.62 total file boot and post result I have same problem use Medusa box repair with model S8530 and repair file S8530 on suporrt site then flash friwmare S8530 will all OK |
no dont try this ur phone imei isss curropted |
Hotfile.com: One click file hosting: SHW-M210S_SKT_1_20110725135129.zip original firmware found on google search |
Hw can i flash men with this file... |
