03-29-2021, 06:47 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | SM-C5000 FRP lock is successfully reseted Code: Welcome to Octoplus Box Samsung software version 3.0.2.0 Card S/N : 00000E47 ----------------------------------------------------------------------------------- To connect SM-J5108 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-C5000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Work ID: 0000000000CD4648 Platform: Samsung Android Selected port: COM1 Selected model: SM-C5000 Operation: Reset FRP - UserData Reset FRP/ Reactivation lock operation for SM-C5000 will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-C5000 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 3.0.2.0 Software version. |
The Following 2 Users Say Thank You to naveedullah0044 For This Useful Post: |
