Sm-g130h/ds SUCCES WRITE CERT BUT STILL IMEI NULL PHONE SUCCES FLASH USING KIES ONLINE WITH SAME SN WITH BACK COVER, BUT IMEI STILL NULL Platform: Samsung Android Selected port: COM173 Selected model: SM-G130H Reading info, please wait... Detected phone model: SM-G130H Firmware compiled date: Fri Dec 26 21:10:18 KST 2014 PDA version: G130HXXU0ANL3 CSC version: G130HOLB0ANL2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM173 Selected model: SM-G130H Selected file: G:\samsung\sm-g130h\Cert-SM-G313H_ 356128060034609_R51F909AZQW.cert Detected phone model: SM-G130H Firmware compiled date: Fri Dec 26 21:10:18 KST 2014 PDA version: G130HXXU0ANL3 CSC version: G130HOLB0ANL2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate1... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes |
Hello. As You can see from this Software log, modem part is damaged in your device: Quote:
At first, try re-flash the device with different firmwares and check, whether modem is correct (not Unknown). It is not possible to repair IMEI, if phone's modem part is damaged. |
PHONE SUCCES FLASH USING KIES ONLINE WITH SAME SN WITH BACK COVER, BUT IMEI STILL NULL try another fw still modem unknown |
Try to write different firmwares, which You can find. If after of writing all firmwares, "SW version" is still Unknown, most likely, your device has HW issues. |
