SM-G313HN root/unlock? SM-G313HN root/unlock? i see on support u have rooting and cert files, but via software it's not supported for erase, write and flashing. |
Hello. Read/Write Cert is currently not supported for this device. We have prepared and sent You test Software version to PM. If You have SM-G313HN in hands, install this Software version, root the phone, connect the phone as GT-S7583T and try to make "Read Security" and "Read Cert". Post here the result. |
I found solution for rooting but need to flash another firmware. Another time when i have this phone in hands will contact with u on skype. |
sm-g313hn can i have the software test version?i have problem with this device..is rooted now..but when i try to repair imei the software give me this : reading security failed write imei failed thank you |
@ davyde1190 Quote:
Do the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Run the Software. 3. Root the phone (try to use another root). 4. Take out SIM and SD cards from the phone. 5. Make Repair IMEI. 6. Close the Software. 7. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here the link, we will research, where can be the problem with your device. |
OK, we will research and say You the result. |
We have prepared and sent You test Software version to PM. Try this Software and post here the result. |
