04-28-2015, 18:13 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: HGJIKL
Member: 1360208 Status: Offline Thanks Meter: 133 | why still asking for root,if using last update? 1.9.3 ----------------------------------------------------------------------------- To connect GT-I9003 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Press "Read Info" in software. ----------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM96 Selected model: GT-I9300 Searching for a phone. Please wait... Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM96 Phone connection failed ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM96 Selected model: GT-I9300 Searching for a phone. Please wait... Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM96 Phone connection failed Selected firmware file: Root_GT-I9300_4.3.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9300 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM96 Selected model: GT-I9300 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9300 Firmware compiled date: Thu Nov 28 21:07:41 KST 2013 PDA version: I9300XXUGMK6 CSC version: I9300YOGGML1 SW version: I9300XXUGMK6 Phone IMEI: 355449055332472 Phone SN: RF1CC739WBN Android version: 4.3 (JSS15J) Checking Root: Phone is not Rooted. Rooting phone... Phone unlocking failed ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM96 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Thu Nov 28 21:07:41 KST 2013 PDA version: I9300XXUGMK6 CSC version: I9300YOGGML1 SW version: I9300XXUGMK6 Phone IMEI: 355449055332472 Phone SN: RF1CC739WBN Android version: 4.3 (JSS15J) Checking Root: Phone is not Rooted. Rooting phone... Phone unlocking failed ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM281 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Thu Nov 28 21:07:41 KST 2013 PDA version: I9300XXUGMK6 CSC version: I9300YOGGML1 SW version: I9300XXUGMK6 Phone IMEI: 355449055332472 Phone SN: RF1CC739WBN Android version: 4.3 (JSS15J) Checking Root: Phone is not Rooted. Rooting phone... Phone unlocking failed why still asking for root with 1.9.3 update? Last edited by Octopus box; 04-29-2015 at 06:07. |
04-28-2015, 18:25 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. Please carefully read release notes of 1.9.3 update. GT-I9300 is not in range of the models, for which new unlock algorithm was added (http://forum.gsmhosting.com/vbb/f684...added-1940873/). Root the phone and repeat "Unlock" operation. |
