10-01-2015, 13:13 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: conakry Age: 42
Member: 352958 Status: Offline Sonork: 100.1585201 Thanks Meter: 132 | g925t root error try to root g925t getting error this is error i get on phone custom binary boot.blocked by frp lock |
10-01-2015, 13:14 | #2 (permalink) |
Member: 352958 Status: Offline Sonork: 100.1585201 Thanks Meter: 132 | this is error i get from octopus box Welcome to Octoplus/Octopus Box Samsung software version 2.0.4 ----------------------------------------------------------------------------------- To connect SM-G900P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#3424#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G925T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: sm-g925t_root_android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G925T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing Firmware Failed anyway to root this phone |
10-01-2015, 13:28 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Unfortunately You can not process the phone, which has FRP lock. Removal of this lock is currently not supported. |
