07-31-2018, 10:06 | #1 (permalink) |
Major Poster Join Date: Jul 2013
Member: 1990444 Status: Offline Thanks Meter: 1 | FRP SM-G930F 8.0 PACH May 2018 help [Answered] Country / RegionItaly PDA G930FXXU2ERE8 ITV Product Code CSC G930FITV2ERE8 Phone G930FXXU2ERD6 I can not downgrade how can i do to remove frp? which last file combination for this firmware? Thank you Last edited by Octopus box; 07-31-2018 at 10:22. |
07-31-2018, 10:21 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Yes, mr. CHANDARAKK is right. Try to use UFS method or use proper Combination firmware. As your device modem firmware version is binary 2 (U2): Quote:
Please http://forum.gsmhosting.com/vbb/f103...wares-2336370/. Also read Software manual ("Help" button in Software) on how to perform "Reset FRP" operation/procedure. If You don't want to risk to damage the device using Combination firmwares or if You don't have proper (neccessary) Combination firmware, You can reset FRP in this device via Octoplus Samsung Factory Reset FRP / Reactivation Service, using Octoplus Server Credits. Last edited by Octopus box; 07-31-2018 at 10:29. | |
07-31-2018, 11:37 | #4 (permalink) |
Member: 1990444 Status: Offline Thanks Meter: 1 | thanks for the answer, now I managed to write with the file combination: COMBINATION_FA60_G930FXXU2ARA2 I have enabled debugging ok, now I can not get back to the original firmware, I selected only BL - AP - CSC (HOME CSC file) always FRP ACTIVE. HEELP |
07-31-2018, 12:31 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | At first post here full Software log with all of performed operations with the device, we will check it. Probably You have not read Software manual attentively and have written full Combination firmware instead of writing only boot image from Combination firmware. |
