SM-G930T1 FRP Reset question [Answered] i can't find combination on Octoplus support area and no option to remove FRP anyone have combination for G930T1 please post it here thanks |
Got to know what #android version are running on the phone then can ask for comb. Enviado de meu SM-G935F usando Tapatalk |
android 8.0 binary 4 Envoyé de mon iPhone en utilisant Tapatalk |
As far as i know all s7 variants from USA has firmware compatibility, you can flash an eng root to enable adb, also can downgrade if root doesnt works. This combination file is in support: COMBINATION_FA60_G930TUCU4AQB1_CL7396841_QB1270377 8_REV02.oct I use to flash G930VVZW4API3 on s7 bit 4, this is android 6.0 and allows enable usb debugging when power up the phone while press volume down and power at same time. BTW you need connect to a wifi network to bypass frp by adb., otherwise you'll e stucked on initial configuration from verizon wireless devices. |
Hello. Yes, try to do as suggested mr. mexiquense in the previous post. If You don't want to risk to damage your device using incompatible Combination firmware, You can reset FRP via Octoplus Factory Reset FRP / Reactivation Service. Operation is not free and require Octoplus Server Credits, please look here: http://forum.gsmhosting.com/vbb/f684...018-a-2263590/. |
Try Flash this: Samsung G930x QC Eng Boot https://www.androidfilehost.com/?fid=457095661767142259 If it doesn’t work, downgrade to 7.0 first before flashing Eng Boot.. Let me know! Good luck! Sent from my iPhone using Tapatalk |
