Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 07-13-2016, 08:41   #1 (permalink)
cronicle861's Avatar
Member: 656774
Thanks Meter: 35
SM-G935 Need Help cant finish downloading Resources
Good day
i wanted to do FRP process for this unit but it keep failing on downloading the resources needed can some on help me download it manually.
37mb worth of file
Unit SM-G935F
sm-g935_exy_rootedBoot.oct
sm-g935_exy_rootedBoot.md5
Thank you!
Old 07-13-2016, 10:27   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,957
Hello.
Please check your PM, we've sent You the file.
Old 09-11-2016, 17:51   #3 (permalink)
Member: 1141098
Sonork: 100.1625915
Thanks Meter: 35
Samsung S7 SM-G930F Stuck at Logo after reset screen lock
any idia how to fix because i dont want to lose data
here is the log
Welcome to Octoplus/Octopus Box Samsung software version 2.3.3
To connect SM-G935F phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Selected firmware file: g935f_twrp-3.oct
Please put the phone into Download Mode and connect USB cable.
To put SM-G935F into Download Mode, You have to perform the
following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Found phone on
Firmware write started.
Writing RECOVERY section...
RECOVERY section has been written successfully.
Writing Firmware Failed
Performed by 2.3.3 software version
Platform: Samsung Android
Selected port: COM1
Selected model: SM-G935F
Connecting to server...
Connecting to server...Ok!
Checking resource files...
Resource files already downloaded.
following steps:
Waiting for phone...
Writing Boot section...
Boot section has been written successfully.
Searching for a phone. Please wait...
Old 09-12-2016, 09:06   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to reflash the phone, then repeat "Reset FRP" operation.
Page generated in 0.11212 seconds with 7 queries
