11-18-2016, 20:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | G920p 6.0.1 Emergency calls only [Solved] i found this menu IOTHiddenMenu Usbsetting menu Lte mode menu Testmode menu ##data#menu ##msl#menu ##debug#menu ##test#menu ##Phone util#menu ##rtn#menu ##Scrtn#menu Last edited by Octopus box; 11-21-2016 at 08:29. |
11-18-2016, 22:20 | #3 (permalink) |
Freak Poster Join Date: Aug 2016
Member: 2616438 Status: Offline Thanks Meter: 147 | Look for gcf and set it to on even if it ia on make it off and on again phone will reboot You can find gcf in: Umts /debug screen/ phone control/ Network control/ gcf Or in: Ue setting & info/ setting/ gcf Sent from my SM-N920C using Tapatalk |
11-19-2016, 08:46 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. What is the exactly state of your phone? Did You check imei and network? Also, please make sure that You perform these steps: Check, whether GSM/??GPRS/WCDMA GCF is turned on in your phone: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following:I.Press UMTSPress DEBUG SCREENPress PHONE CONTROLPress NETWORK CONTROLSet GCF to ONII.Press [2] UE SETTING & INFOPress [1] SETTINGSPress [4] GCFSet [1] GSM/??GPRS/WCDMA GCF to ONAfter these actions go to Settings -> Mobile Networks and Set Network Mode to Automatic, or GSM. |
11-19-2016, 13:46 | #5 (permalink) | |
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | Quote:
ur steps to get Hidden menu i do all this steps and i get this Hidden menu but its diffrent look to picture ihave not UMTS... to finich checking the phone working before (511) after update no signal (6.0.1 ) imei is oki | |
11-19-2016, 16:35 | #6 (permalink) |
Member: 2616438 Status: Offline Thanks Meter: 147 | Check one of the options in the hidden menu its over their maybe debug menu or msl Sent from my SM-N920C using Tapatalk |
The Following User Says Thank You to wadda7o For This Useful Post: |
11-19-2016, 18:04 | #8 (permalink) |
Member: 2616438 Status: Offline Thanks Meter: 147 | In testmode menu you will find ue setting & info Choose it then choose settings you will find gcf Sent from my SM-N920C using Tapatalk |
The Following 3 Users Say Thank You to wadda7o For This Useful Post: |
