sm-g935f read cert problem [Solved] Hi, when i try to read cert on the g935f it give me this error: Welcome to Octoplus/Octopus Box Samsung software version 2.3.7 ----------------------------------------------------------------------------------- To connect SM-G935F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-G935F Detected phone model: SM-G935F Firmware compiled date: Tue Aug 9 18:50:34 KST 2016 PDA version: G935FXXU1BPH6 CSC version: G935FWIN1BPH1 SW version: G935FXXU1BPH1 Phone SN: RF8H334TXKN Android version: 6.0.1 (MMB29K) Sales code: WIN Country: ITALY HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Codename: hero2ltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G935F-Unknown24-09-2016_23-51-11-.asec file Initializing exploit... Executing exploit... Exploit has been executed successfully Reading Certificate... Checking Certificate file... Checking Certificate failed Reading Certificate failed Performed by 2.3.7 Software version. I have flashed firmware on the phone but result is the same, anyone can help me? thanks in advance |
Me also face same issue may be at the moment not aupported |
Hello. In the latest firmware versions Samsung close security hole and You can't perform Direct Unlock or Red Cert on new version of firmwares. You can try to downgrade phone's firmware (write older, by release date, version of firmware) but on your own risk, after repeat Unlock or Read Cert operation. |
many thanks, i flash on the phone other modem version and all procedure done. Read Cert - Write Cert ecc.... |
@nerowebx That's good, please post here full Software log and say, which modem You used exactly. Thanks. |
i also need solution plz share step by step how can do |
Welcome to Octoplus/Octopus Box Samsung software version 2.3.8 ----------------------------------------------------------------------------------- To connect SM-G935F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM423 Selected model: SM-G935F Detected phone model: SM-G935F Firmware compiled date: Mon Jul 4 11:21:10 KST 2016 PDA version: G935FXXS1APG3 CSC version: G935FOJV1APF1 SW version: G935FXXU1APB6 Phone SN: RF8H51W2BZB Android version: 6.0.1 (MMB29K) Sales code: MTZ Country: Zambia HW platform: exynos5 HW Chip: exynos8890 HW Modem: SHANNON335 Codename: hero2ltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G935F-Unknown19-10-2016_19-34-53-.asec file Initializing exploit... Executing exploit... Exploit has been executed successfully Reading Certificate... Checking Certificate file... Phone KeyID: 445 Certificate file successfully checked Certificate read successfully Performed by 2.3.8 Software version. |
Thanks team first write this modem file :MODEM_G935F_PB6.tar then read cert all done :) |
Please faisal.u7 Where did you find this modem? |
firmwer afg Afghanistan 6.0.1 G935FXXU1APB6 G935FOJV1APB9 date 11/03/2016 not last modem not new |
And exactly what are you going to do with the cert. You cant write it to any other phone. |
